Battery Backup Issues
  1. Maxby23
    Froyo Dec 6, 2016
    Maxby23 , Dec 6, 2016 :
    I am on Stock Recovery and Official Oxygen OS 3.2.8 and i am getting less than 4 hours of screen time even if i dont play any games or use high memory apps. My LTE is on for 70℅ of time. Maybe i am facing this thing after this updating to 3.2.8 before it was going good and smooth. Is anyone facing the same problem and knows how to cure it.
  2. robogo
    Honeycomb Dec 6, 2016
    robogo , Dec 6, 2016 :
    Factory reset, don't install any apps. If it still continues, something is wrong.
    Nishant51071 and G_venkat_r_fFci like this.
  3. Bartnl
    Lollipop Dec 6, 2016
    Bartnl , Dec 6, 2016 :
    How long ago did you do the update?
    After every update and every factory reset the battery needs to settle again. This can take up from 5 to 7 days.
  4. jamesm182
    Eclair Dec 6, 2016
  5. Nishant51071
    Froyo Dec 7, 2016
    Nishant51071 , Dec 7, 2016 :
    do a factory reset and then monitor
    or if you dont want to reset then clear cache and try to monitor your usage with just constant screen on with flight mode, also close all the background apps and clear ram before starting,
    if the problem is still there then contact care/service centre.
  6. laserjet
    Jelly Bean Dec 7, 2016
  7. Maxby23
    Froyo Dec 7, 2016
    Maxby23 , Dec 7, 2016 :
    i don't remember it exactly but can say that it has been longer about 2 weeks...
  8. Maxby23
    Froyo Dec 7, 2016
    i should clear cache of? And how to do it.
    when i boot up in recovery mode it only shows wipe data and cache but there's no option to only clean cache partition.. Gimme some hints
  9. Nishant51071
    Froyo Dec 7, 2016
    try one thing clear cache data of all apps from settings and then going into storage and clearing chache there and then try the rest as i told.
  10. whodatboi
    KitKat Dec 8, 2016
    whodatboi , Dec 8, 2016 :
    install a ROM. having the same issue and I came from a full loaded RR rom.
  11. 1darshan
    Gingerbread Dec 8, 2016
