Battery Backup via OnePlus 7 Pro
  1. Singhnaman
    Gingerbread Oct 17, 2021
  2. Shailender Sharma
    Nougat Oct 17, 2021
    nerdkabir and Artemus like this.
  3. Singhnaman
    Singhnaman , via OnePlus 7 Pro , Oct 17, 2021 :
    battery health is 86% do i need to replace it??
    Shailender Sharma likes this.
  4. Shailender Sharma
    Nougat Oct 17, 2021
    Shailender Sharma , Oct 17, 2021 :
    It's okay for the time being. If the battery health is less than 70 per cent, then it is advisable to get it replaced.
  5. Singhnaman
    but i m hardly getting screen on time of 3 and half hours even on 60hz
  6. Shailender Sharma
    Nougat Oct 17, 2021
    J4t1np4r3kh and Singhnaman like this.
  7. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Oct 17, 2021
    Liehjan , Oct 17, 2021 :
    You could do a factory reset and see improvement. you should be able to get that screen on time with 90hz on too.
  8. Singhnaman
    i already performed factory reset there are too many bugs sometimes i am not able to pull down notification panel in landscape mode
  9. Liehjan
    On what build are you, IN/GLOBAL/EU?
  10. Singhnaman
    Liehjan likes this.
  11. Liehjan
    Some issues might be only in IN build. Remember to report the issues you find, that's important for fixing existing bugs.
    I saw the screenshot of your battery usage. Instagram seems to drain a lot, so I would clear data and cache from Instagram app.
  12. Singhnaman
    my battery dies to 90% from 100% within 5 mins and without any usage
  13. Liehjan
    That's just an estimate. Battery can drop fast in the beginning and then slow down in the end. The only thing that you should look at is real life battery life, not the estimate numbers.
