11
Battery/Charging Battery backup
  1. Waqar_100
    Donut Jan 9, 2017
    Waqar_100 , Jan 9, 2017 :
    Is anyone out there who is facing problems regarding battery backup after new update or it's just me . The battery backup is considerably reduced after new update
  2. G_Mr_....
    Jelly Bean Jan 9, 2017
    G_Mr_.... , Jan 9, 2017 :
    Hi try clearing your cache partition, if no change then perform a factory reset.
    Hope this helps.
    Arul karthik and Waqar_100 like this.
  3. ank0707
    Eclair Jan 10, 2017
  4. Luca Pretini
    Donut Jan 11, 2017
  5. hetal modha
    Cupcake Jan 11, 2017
    hetal modha , Jan 11, 2017 :
    Same problem and specially after the VoLTE was downloaded by company.
    once the mobile battery is low then it takes more than 8 hours to full charge...
    Why ? Any suggestions on this ?
    luarluz, Sainath redsy and Pramod.P27 like this.
  6. G_AMIT_CHATURVEDI_RBsa
    Honeycomb Jan 11, 2017
    G_AMIT_CHATURVEDI_RBsa , Jan 11, 2017 :
    change ur adapter or type c cable. In my case, cable was the problem. I m using normal cable and a type c converter , it charges very fast.
    Sainath redsy likes this.
  7. hetal modha
    I am using type C cable which had come along with the mobile and the charger.
    I did not have this problem before, this has just cropped up after the new software company had launched and also the VoLTE version downloaded.
    Any other advice ?
    How do I uninstall the new version of software ?
  8. F_Yash_Shinde_RzGi
    praveenjayram likes this.
  9. Prashanth Swargam
  10. Mitul2017
    Mitul2017 , Jan 11, 2017 :
    Yes the battery drains out faster once I update,
    When is NEW OS 4 available in Bombay India?
    kobleznbitz likes this.
  11. praveenjayram
    praveenjayram , Jan 11, 2017 :
    was this a bad idea for me to download the update
    Khan iqbal akhtar likes this.
  12. G_Prateek_Pal_uaLr
  13. Raiden_597
    Donut Jan 11, 2017
    Raiden_597 , Jan 11, 2017 :
    The battery backup has gone downhill after the update. I hardly get 3-4 hours of SOT.
  14. manukm123
    Eclair Jan 11, 2017
  15. rohit9145
    rohit9145 , Jan 11, 2017 :
    Same here. The battery is drains too fast. Also it takes a lot of time to charge
  16. G_sharat_dodeja_UOBb
  17. Khan iqbal akhtar
  18. Mitul2017
  19. Vrushali Rathod
    Vrushali Rathod , Jan 11, 2017 :
    I'm facing the same issues with the battery like you. It charges only when the phone is switched off. And it takes 14 hours to charge fully. But drains within minutes.
    Even when the phone is on stand by mode, battery drains. I uninstalled fb, messenger, still no improvement. And it is all happening post update. The update is really nice. But, What is the use of update if we don't have the battery itself?
    One plus team, hope you are reading it. Please fix it ASAP!
    manukm123 and Waqar_100 like this.
  20. AdershThottungal
    Froyo Jan 11, 2017
    AdershThottungal , Jan 11, 2017 :
    I m also facing the same battery draining issues in my OP3T ..don't hv FB or messenger app in my mob.m only using WhatsApp.,but unfortunately battery is draining so faster ...mng I just charged ,without doing anything ( mobile data n wifi both are off) but it drained from 100 to 60 within 50 mins ... please do the needful team OnePlus
    manukm123 likes this.
