924
Battery Calibration/Heating Tips: How To Improve Battery Life!!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    97 vote(s)
    5.5%
  2. 3.5 Hours
    74 vote(s)
    4.2%
  3. 4 Hours
    170 vote(s)
    9.6%
  4. 4.5 Hours
    192 vote(s)
    10.9%
  5. 5 Hours
    224 vote(s)
    12.7%
  6. 5.5 Hours
    192 vote(s)
    10.9%
  7. 6+ Hours
    815 vote(s)
    46.2%
  1. G_Khushal_Galaiya_BgmG
    Cupcake Aug 11, 2017
  2. Hamlat
    Hamlat , Aug 11, 2017 :
    Bonjour j'ai mon oneplus 5 depuis hier j'ai donc eu la mise à jour 4.5.8 directement et je trouve que le téléphone se décharge assez vite.avant j'avais un 3T et il duré plus longtemps !!!!
  3. pratik_2212
    pratik_2212 , Aug 11, 2017 :
    its been a day i got my one plus 5 and i started using it. but when my phone was not in use battery started to drain
  4. Bartnl
    Lollipop Aug 11, 2017
    Bartnl , Aug 11, 2017 :
    You can't conclude after one day of use that your battery is draining.
    It needs a couple of charging cycles to settle down.
    Wait a couple of days and if it still drains, come back to the forum and use the search function with keyword battery.
    There are loads of threads about this with tips and tricks that might help you.
    Nezumi_ likes this.
  5. bouglais
    Froyo Aug 11, 2017
    bouglais , Aug 11, 2017 :
    Ur right. but they love complaining and at same time praising oneplus and then hating.
  6. suraj malakar
  7. Eshan_Anand
    Ice Cream Sandwich Aug 11, 2017
  8. Rohit.lancers
  9. FruityFaiz
    Gingerbread Aug 11, 2017
    FruityFaiz , Aug 11, 2017 :
    How much battery u getting on 4.5.3
  10. lennard1000
    Eclair Aug 11, 2017
  11. Goodman854
    Froyo Aug 11, 2017
    Goodman854 , Aug 11, 2017 :
    not sure never did a proper test yet but here's some reference stuff
    FruityFaiz likes this.
  12. FruityFaiz
  13. Tricolour
    Froyo Aug 11, 2017
    Tricolour , Aug 11, 2017 :
    Running on latest version 4.5.8.
    Battery leve on 32% and screen on time is more than 7 hrs.
    DonM786 and faizarsyadw like this.
  14. Goodman854
    Froyo Aug 11, 2017
    in that screen shot 11 hours but do note that it was charged at points and is the summer so I have to leave display on Max brightness sometimes
  15. tbonnie
    Donut Aug 11, 2017
  16. Dunnow
    The Lab - OnePlus 6 Reviewer Aug 11, 2017
    Dunnow , Aug 11, 2017 :
    7h in your phone in one day? That is just sad. There's a world past the screen dude...
  17. Dunnow
    Sonia, honestly. I would stop posting that guide. Those instructions are made to kill the smart part of smartphone... people will lose out on features and usability due to it. That guide should've never been posted.
    plus it contains a lot, A LOT of misleading information.
    IE: Disable some screen gestures.
    The kernel either keeps the touch panel alive or not depending if there's 1 or more gestures to be listened to or not.
    Disabling 4 gestures out of 5 will not save ANY battery at all. While at the same time, some users, might disable features just thinking "well, not controlling my media from the screen is not that much of a loss, but i will keep the camera one"
    see the point? it's filled with actual stupid concepts and misconceptions assumed by many people in the community that misguide people to understand how to properly manage power consumption at these extremes.
    Furthermore, others can cause actual misbehaviour on apps or worse, at a system level.
    this one, for example, can very well prevent the user to get notification of things that might be of importance to him. Missing on possible appointments with friends by whatsapp or completely forgetting about a meeting you had because you were not able to sync the calendar properly due to the extreme doze, therefore, no notifications came in.
    This one will prevent users to log in into a new device and find most data from applications and configurations from being setup at start.
    Results in lost contacts if phone needs to be formatted (which CS insists on doing almost every time there's an issue)
    Also might prevent the user from backing up third party data, such as whatsapp cloud storages or Google Photos backups, which at the same time, will keep the user's phone filled with data that upon lost / stolen will be never recoverable. Not to mention worse implications.
    Telling users to prevent automatic sync is probably, the worst advice one should give while talking about smartphones.
    I could keep going on almost every single point, but just picked the most crucial ones to get my point across
  18. FruityFaiz
    wow better than what I get on 4.5.7
  19. Goodman854
    Froyo Aug 11, 2017
    feel free to suggest any test you want me to do and I'll come back with the results
  20. FruityFaiz
    Thanks but there is nothing really. You have charged your phone 3 times in 29 hours. I would have charged mine 4-5.
