924
Battery Calibration/Heating Tips: How To Improve Battery Life!!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    97 vote(s)
    5.5%
  2. 3.5 Hours
    74 vote(s)
    4.2%
  3. 4 Hours
    170 vote(s)
    9.6%
  4. 4.5 Hours
    192 vote(s)
    10.9%
  5. 5 Hours
    224 vote(s)
    12.7%
  6. 5.5 Hours
    192 vote(s)
    10.9%
  7. 6+ Hours
    815 vote(s)
    46.2%
  1. MrHari_theCarguy
    Jelly Bean Aug 13, 2017
  2. F_Jorden_Grewal_QmtA
    Ice Cream Sandwich Aug 13, 2017
    F_Jorden_Grewal_QmtA , Aug 13, 2017 :
    yes you would get that battery like if you stay indoors.
    battery life is phenomenal on OnePlus 5 no doubt about that
    but I have noticed 10 % drop in battery after new OTA 458. and apps, mostly games are randomly close by itself. it wasn't a problem in 456
  3. nitinyadavyo
    Gingerbread Aug 13, 2017
  4. sharan.salem
    sharan.salem , Aug 13, 2017 :
    Hi Funk wizard, here are the stats you have asked for.
    I stated from 90% of battery, i don't know for what reason Wifi and Idle parts were consuming this much of change and when saw the time on for these two features it was the same as time since i plucked my mobile from charging (1 day 11 hrs). I have cleared my system and app cache before the start of this cycle.
    Also as posted previously where can i find the hidden settings as you have mentioned to control the background running apps.
    Also how frequently should i be clearing the system cache as i clean my app cache daily before i go to sleep.
    Thanks,
    Peace [e]270c[/e]️
  5. rushavgandhi
    Eclair Aug 13, 2017
    Ravi BINAVAT likes this.
  6. Bartnl
    Lollipop Aug 13, 2017
    Bartnl , Aug 13, 2017 :
    and what is the temperature of what you are calling heat?
    A metal body always transfers heat more as a plastic body.
    If you want to have more info, use the search function with keyword heat.
  7. gandharvdua
    Cupcake Aug 13, 2017
    gandharvdua , Aug 13, 2017 :
    where did you find that it's heating because when it's chargr it get pretty heats up and when I was in my car I felt phone pretty warmed up did you find your phone heats up in these situation
  8. rushavgandhi
    Eclair Aug 13, 2017
    rushavgandhi , Aug 13, 2017 :
    dude,it heats and you can feel even if you put it in your wallet! i can understand as it is metal body it happens at certain level but not this much!!
  9. rushavgandhi
    Eclair Aug 13, 2017
    found it during charging
  10. Bartnl
    Dude, am I saying it does not heat?
    All I am saying is that you should come up with the temperature instead of the word heat.
  11. rushavgandhi
    Eclair Aug 13, 2017
    word doesnt matter what i'm trying to convey matters.
  12. Bartnl
    Okay mister attitude.
  13. rushavgandhi
    Eclair Aug 13, 2017
    not really dude just shared if it can be improved! cus after some usage this issue might increase!
  14. Bartnl
    That's why you need to come up with temperatures as your perception of heat is different then that from others.
    If you would open a live chat or go to a service centre for this they also want to know the temperature. Not just the info that it gets hot.
  15. rushavgandhi
    Eclair Aug 13, 2017
    ok will visit service center thank you
  16. ScRuFFy7
    Eclair Aug 13, 2017
    ScRuFFy7 , Aug 13, 2017 :
    Here are my battery stats:
    I am rooted running stock OOS with blu_spark. Battery life is really good for me. 100% to 5% with 7h45m+ of SOT and total up time of 1d2h.
    Cheers!
  17. gandharvdua
    yeah while charging I felt pretty warmed up but there is a app which gives you the temperature see it and I have read in one of the forum that 37-41°c is ok and check with service center also and share the feedback with them
  18. dboyrusky
    dboyrusky , Aug 13, 2017 :
    Screen brightness half way, Bluetooth on and location on, nfc off. Doze on except the very aggressive option...
  19. dboyrusky
    App wifi/multi broadcast filter on in the developer settings
  20. dboyrusky
    Auto sync like for Google account?
