880
Battery Calibration/Heating Tips: How To Improve Battery Life!!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    94 vote(s)
    5.4%
  2. 3.5 Hours
    73 vote(s)
    4.2%
  3. 4 Hours
    168 vote(s)
    9.7%
  4. 4.5 Hours
    189 vote(s)
    10.9%
  5. 5 Hours
    221 vote(s)
    12.7%
  6. 5.5 Hours
    188 vote(s)
    10.8%
  7. 6+ Hours
    802 vote(s)
    46.2%
  1. X1508837514693
    Cupcake Oct 24, 2017
    ShahBhumi0409 likes this.
  2. pradeep.pal96
  3. dasoul
    Honeycomb Oct 24, 2017
    dasoul , Oct 24, 2017 :
    Than do something about it!
    Check which apps drain most power and do something about it! God damnit.
  4. remedy
    KitKat Oct 24, 2017
    sk.one and Deactivated User like this.
  5. Intruder71
    Lollipop Oct 24, 2017
    Intruder71 , Oct 24, 2017 :
    Crying like a baby...... How old are you?
    Deactivated User likes this.
  6. Sidag14799
  7. @shreyanshkumraw
  8. 9478441880
    Froyo Oct 24, 2017
    9478441880 , Oct 24, 2017 :
    after updating device to 4.5.13 from 4.5.10 heating issue and battery drain issue is there i have tried all solution but none of them work when oneplus will release update for this issue
  9. Sidag14799
    Sidag14799 , Oct 24, 2017 :
    i too have battery drainage issue.
  10. X1509015850406
    Cupcake Oct 26, 2017
    X1509015850406 , Oct 26, 2017 :
    i am having one plus 5 but my Battery Drains like anything. after charging to 100% i need to plug in within 4 hrs for charging. need help
  11. Funk Wizard
    Lollipop Moderator Oct 26, 2017
    Funk Wizard , Oct 26, 2017 :
    Merged with the battery life thread, follow the opening post to check if you can get some improvement.
    X1509015850406 likes this.
  12. Sridhar Ananthanarayanan
    Lollipop Oct 26, 2017
    Sridhar Ananthanarayanan , Oct 26, 2017 :
    just wanted to report a bug to the support team. but could not do so because the IMEI field was left blank.
    please do not insist on information which is unnecessary.
    you may expect more people coming forward with bug reports.
  13. Sidag14799
  14. Palak0091
    Palak0091 , Oct 26, 2017 :
    Been facing issues since the update to Oxygen OS 4.5.13
    Draining faster than before the update. From 100% to 90% is even quicker.
    It was 89% and 13 hours left a few minutes ago before I took the screenshot. How can this issue be resolved !?
  15. germain99
  16. Palak0091
    I went through all threaded posts and none seemed to answer the problem. It was necessary to start a new thread because earlier posts have a way too long on goings. Thanks anyways for your input.
  17. SimonRam
    SimonRam , Oct 26, 2017 :
    Mine's been a bit the same, heating too.
    No change in apps.
    Some kind of bug.
  18. remedy
    KitKat Oct 26, 2017
  19. Senti3nt
    Ice Cream Sandwich Oct 26, 2017
    Senti3nt , Oct 26, 2017 :
    I don't see any issue with the battery. It's fine for the usage. Battery takes some recharge cycle to settle a update so if you don't have patience then you should delete cache files and wipe & delete data and cache files in recovery and reboot. Let the battery discharge till 5% or even less or 0% and recharge again.
  20. Senti3nt
    Also there would be thousand thread about battery and update. May be you searched with your eyes closed.
