948
Battery Calibration/Heating Tips: How To Improve Battery Life!!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    102 vote(s)
    5.7%
  2. 3.5 Hours
    79 vote(s)
    4.4%
  3. 4 Hours
    173 vote(s)
    9.6%
  4. 4.5 Hours
    199 vote(s)
    11.0%
  5. 5 Hours
    232 vote(s)
    12.9%
  6. 5.5 Hours
    194 vote(s)
    10.8%
  7. 6+ Hours
    823 vote(s)
    45.7%
  1. Guilherme Fontes
    Honeycomb Feb 6, 2018
    Guilherme Fontes , Feb 6, 2018 :
    Been having this horrible SOT and battery life in general for a few days now (running clean flashed 5.0.2).
    I keep saying in some threads, my battery life in nougat was great, I could just charge until 80% and when I reached 20% at the end of the day I would get 5-6hours SOT. Now I can only get that amount of SOT if I use it continually (starting at 100% battery to ~10%.
    If I just want to get that SOT in a day use, I just can't lol.
    dashingfahad11 and Rafaxtz3 like this.
  2. Deactivated User
    Feb 6, 2018
  3. likithbommana
    Eclair Feb 7, 2018
    likithbommana , Feb 7, 2018 :
    my op-5 after last update..is getting heated up in quick sessions..which was not the case till now..what is the issue?
  4. pablofg1978
    Head Moderator Head Moderator Feb 7, 2018
    pablofg1978 , Feb 7, 2018 :
    Thread merged
  5. dashingfahad11
    Gingerbread Feb 7, 2018
    dashingfahad11 , Feb 7, 2018 :
    Sameeeee!!?! And some of this people are arguing that Oreo is so much better. ughhh
    Guilherme Fontes likes this.
  6. Guilherme Fontes
    Honeycomb Feb 7, 2018
    Guilherme Fontes , Feb 7, 2018 :
    Do you happen to have Android Wear? If so, try to disable cloud sync from the app settings.
  7. dashingfahad11
    No I don't.
  8. Guilherme Fontes
    Mh ok. I am just asking that because my battery as been much better after disabling that option in Android Wear app. But I can tell that still, standby battery drain is a problem in Oreo. Did you already try to clean install Oreo and clean cache?
  9. dashingfahad11
    No I just updated my phone from nougat. And yes I cleared the cache from recovery. And I bet resetting or clean install won't fix this thing for sure 101%. OnePlus seriously needs to do something to fix this. Thinking about reverting back to nougat. [e]1f62d[/e]
  10. Guilherme Fontes
    Please try that before rolling back to nougat! It should help a bit at least.
    dashingfahad11 likes this.
  11. dashingfahad11
    Okay man! Thanks a lot for your instant replies. Cheers!
  12. Guilherme Fontes
    No problem!! Keep me in loop! I hope that helps( it should because if you don't clean install some nougat stuff should still be in the phone)
  13. dashingfahad11
    I'll try it. [e]1f44d[/e]
  14. G_mukesh_choudhary_YyhK
    Cupcake Feb 7, 2018
  15. sakearzoo
    Ice Cream Sandwich Feb 7, 2018
  16. pablofg1978
    Thread merged
  17. A1518075042316
    Cupcake Feb 8, 2018
    A1518075042316 , Feb 8, 2018 :
    I am frequently getting this notification in my all new OnePlus 5T.
    It says
    "Potential heating issue"
    "Google play services has been processing the data."
    Please help!
  18. stark2991_PL
    KitKat Feb 8, 2018
    stark2991_PL , Feb 8, 2018 :
    Is your phone heating?
  19. A1518075042316
    Cupcake Feb 8, 2018
  20. MrHari_theCarguy
    Jelly Bean Feb 8, 2018
    MrHari_theCarguy , Feb 8, 2018 :
    then it might be a false trigger, probably a bug,but consider clearing cache of Google play services in settings,see if it helps.
