948
Battery Calibration/Heating Tips: How To Improve Battery Life!!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    102 vote(s)
    5.7%
  2. 3.5 Hours
    79 vote(s)
    4.4%
  3. 4 Hours
    173 vote(s)
    9.6%
  4. 4.5 Hours
    199 vote(s)
    11.0%
  5. 5 Hours
    232 vote(s)
    12.9%
  6. 5.5 Hours
    194 vote(s)
    10.8%
  7. 6+ Hours
    823 vote(s)
    45.7%
  1. abdoul68
    Eclair Jul 9, 2017
  2. a777li
    Cupcake Jul 9, 2017
    mjur likes this.
  3. Far_ish
    Froyo Jul 9, 2017
    Far_ish , Jul 9, 2017 :
    What is force gpu rendering...? I mean what happens if turned on, and what happens when turned off?
  4. F_Akhil_Vincent_anAe
    Cupcake Jul 10, 2017
    F_Akhil_Vincent_anAe , Jul 10, 2017 :
    Hi all...
    Yesterday I slept with 12 percentage battery charge..in powersaver mode in flight mode... morning phone was off..
    Why is this happening ? Battery Drain is so much
    Srisha_Sridhar likes this.
  5. F_Akhil_Vincent_anAe
  6. BPhotigraphy
    Donut Jul 10, 2017
  7. essenin
    Froyo Jul 10, 2017
    essenin , Jul 10, 2017 :
    Try turn on Advanced Optimization:
    Settings-> Battery -> Battery Optimization -> Advanced Optimization
    Manish Bhomia likes this.
  8. G_plusone
    Nougat Jul 10, 2017
    G_plusone , Jul 10, 2017 :
    Because your phone's led was blinking every few seconds plus your regular standy drain.
    Do you have Doze turned on?
  9. G_plusone
    Nougat Jul 10, 2017
    Because some apps which use less than 1% of phone battery which will probably not appear in the stats.
    Also the apps power usage is not exact percentage it is rounded to a whole number so due to these approximations the total combined battery usage of apps will not be 100% or whatever percentage you unplugged your phone from the charger.
  10. F_Akhil_Vincent_anAe
    Doze means ?
  11. F_Akhil_Vincent_anAe
    I used to get around 8 hrs SOT during the initial days...Only after the first update things have changed...I'm using dark theme ..only one sim..no vibration feedback...
    Ananya2703 likes this.
  12. exis_tenz
    Gingerbread Jul 10, 2017
    exis_tenz , Jul 10, 2017 :
    I lose max. 3-4 percent overnight. I have 200+ apps installed. So there must be a REASON why this happens, it ain't standard.
    G_Gurmohit_Singh_wlmc likes this.
  13. Shreejit
    Shreejit , Jul 10, 2017 :
    Same happened to me i was at 35 on battery saving and airplane mode... And after 4 hours all charge was gone
  14. SMK99
  15. G_plusone
    Nougat Jul 10, 2017
    Wipe cache?
  16. F_Akhil_Vincent_anAe
  17. PhilippVandrey
    Froyo Jul 10, 2017
    PhilippVandrey , Jul 10, 2017 :
    Just do it. Worked for me . I wiped 4 GB Data wenn you only have some MB it wont help.
  18. G_Özkan_Eren_tUyG
  19. G_plusone
    Nougat Jul 10, 2017
    After an update It might help.
  20. F_Akhil_Vincent_anAe
