940
Battery Calibration/Heating Tips: How To Improve Battery Life!!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    100 vote(s)
    5.6%
  2. 3.5 Hours
    77 vote(s)
    4.3%
  3. 4 Hours
    173 vote(s)
    9.7%
  4. 4.5 Hours
    195 vote(s)
    10.9%
  5. 5 Hours
    232 vote(s)
    13.0%
  6. 5.5 Hours
    193 vote(s)
    10.8%
  7. 6+ Hours
    820 vote(s)
    45.8%
  1. KULDEEPKUMAR
    Cupcake Aug 7, 2018
  2. X1523971116361
    Cupcake Aug 7, 2018
    X1523971116361 , Aug 7, 2018 :
    wipe cache.. not wipe data.. non of your files will be deleted except cache files..
  3. toastytoast1234
    Marshmallow Aug 7, 2018
    toastytoast1234 , Aug 7, 2018 :
    • Disconnect your phone from the provided charger.
    • Power it off.
    • Carefully place the phone, power adapter, charging cable and anything else you received back in the original packaging.
    • Send it back to OnePlus, you're clearly too dumb to own a phone
    Zaphodrocks likes this.
  4. Logusathish
    Donut Aug 7, 2018
    Logusathish , Aug 7, 2018 :
    Battery Draining issue is common problem for all the oneplus mobiles .I don't know why the company fix this issue.
  5. Jitto Viji
    Cupcake Aug 7, 2018
    Jitto Viji , Aug 7, 2018 :
    After the new update the problem started....
  6. PokiX
    Jelly Bean Aug 7, 2018
    PokiX , Aug 7, 2018 :
    Not enough details to help. Only thing I can say is that I don't have this problem (and most of people don't) so it comes from some bad application.
    Nothing OP can do for you ..
    Factory reset and wait a few days with only preinstalled app.
  7. Zaphodrocks
    Ice Cream Sandwich Aug 7, 2018
    Zaphodrocks , Aug 7, 2018 :
    The company can't fix users I'm afraid. Battery life is great on my phone and I'm using the same OS as you. What's the difference? Apps. There's a hint in it for you.
  8. Logusathish
    Donut Aug 7, 2018
  9. X1513001495748
    Gingerbread Aug 7, 2018
    X1513001495748 , Aug 7, 2018 :
    First find the culprit app which sucks maximum juice from your battery. Then minimize using those apps, and don't use crap apps. If still the same problem exist then factory reset your phone. Even after that your problem isn't resolved then may be your battery life is weakened, You may have to replace it with original one from OnePlus service centre.
  10. pablofg1978
    Head Moderator Head Moderator Aug 7, 2018
    pablofg1978 , Aug 7, 2018 :
    Thread merged
    Please use the search before creating a new thread
  11. Ashish_Behera
    Cupcake Aug 7, 2018
    s15913 and matheussantanabs like this.
  12. the_reckoner
  13. matheussantanabs
    Cupcake Aug 7, 2018
  14. the_reckoner
    the_reckoner , Aug 7, 2018 :
    Lucky OP. wiping cache never seemed to work for me. I've never got more than 4.5 hours of SOT
  15. pablofg1978
    Thread merged
  16. pablofg1978
    Thread merged
  17. mayur.ch17
    Cupcake Aug 7, 2018
    mayur.ch17 , Aug 7, 2018 :
    It is already turned ON. Any other thing I need to turn ON?
  18. pablofg1978
    Thread merged
    mayur.ch17 likes this.
  19. ronakmistry
    Cupcake Aug 7, 2018
    ronakmistry , Aug 7, 2018 :
    I have updated to 5.1.4 and after the update betrry life is poor betrry is not long lasting a whole day
    Rafshan Ar likes this.
  20. boriyawalam
    Cupcake Aug 7, 2018
