940
Battery Calibration/Heating Tips: How To Improve Battery Life!!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    100 vote(s)
    5.6%
  2. 3.5 Hours
    77 vote(s)
    4.3%
  3. 4 Hours
    173 vote(s)
    9.7%
  4. 4.5 Hours
    195 vote(s)
    10.9%
  5. 5 Hours
    232 vote(s)
    13.0%
  6. 5.5 Hours
    193 vote(s)
    10.8%
  7. 6+ Hours
    820 vote(s)
    45.8%
  1. KALYANASUNDARAM R
    Cupcake Jul 20, 2017
  2. syafiq007
    Donut Jul 20, 2017
    KALYANASUNDARAM R likes this.
  3. syafiq007
    Donut Jul 20, 2017
  4. KALYANASUNDARAM R
  5. lostLambda
    Lollipop Jul 20, 2017
    Mr. Vandelay and Android450 like this.
  6. smiteme
  7. syafiq007
    Donut Jul 20, 2017
    syafiq007 , Jul 20, 2017 :
    Reboot to recovery, once booted, choose language, then u can find ur way to wipe cache n dalvik.
    Preferred replying with a solution rather than replying with a "search!!!" command
  8. yashVir0001
  9. BooBzi
    Honeycomb Jul 20, 2017
    BooBzi , Jul 20, 2017 :
    Please provide some schreenshots of battery statistics! Maybe there is something running in background whole time?
  10. BlueDragon_U.D
    Gingerbread Jul 20, 2017
    BlueDragon_U.D , Jul 20, 2017 :
    See. If your area where you are using your phone has a poor network reception. Then this is normal. The phone searches for network if the signals are unstable which results in faster battery drain. Try using your phone on wifi to check. It should be fine.
  11. Shadow.moon
    Froyo Jul 20, 2017
    Shadow.moon , Jul 20, 2017 :
    disable the sync option inside the Google apps .. settings>accounts>Google and disable whichever part of Google is sucking your juice..I did face the similar issue and now it's fine after I did that
  12. surya1991s
  13. jtalexandre
    Ice Cream Sandwich Jul 20, 2017
    jtalexandre , Jul 20, 2017 :
    I am going exactly in the same direction. OP2 > OP5. Should get the new one next week.
    A couple of weeks since you've posted, so are you still happy with the battery life? Thanks.
  14. fbsoft01
    fbsoft01 , Jul 20, 2017 :
    Well, the phone never rebooted out of the blue, very good hardware, pages load fast, Gmaps is stable and in traffic, with auto brightness i have no problems in seeing the display. All good. If you get used to the scroll effect/shadow/ weird effect that a few notice it, then your good to go.
    The fix for battery , was greenify, found a few apps that kept my phone active all night ( ********** and another one )... At 7 am i had a strong 50k traffic, and all the apps were closed... guess not.. :( it was odd,and then i found the culprit... since then i get 2 days with normal usage at least, to 3 days if i push it a little bit. At night i lose at most 10-15 % not as well as i would've hoped, but it is an improvement !
    So it's a win, so far,a few tweeks here and there are missing for now,but, the table is turning from meh,they could've done better t'words good buy :) Still waiting on those fixes, and if they arrive, it's gonna be niice:D. The issues left are software, and this is the biggest problem, cause you never know if they will get fixed or not.
  15. cmanmohan4
    cmanmohan4 , Jul 20, 2017 :
    It is happening with me too . cleared cache and even tried soft reset and hard reset . was even talking to customer care regularly . They formatted my device to OOS 4.5.3 today and the issue still looks unchanged.Don't know what to do ....
  16. G_omkar_mokashi_ncEL
    G_omkar_mokashi_ncEL , Jul 20, 2017 :
    With moderate use 20 to 25 % is left by EOD.
    Coming to heavy use I was traveling and was continously using it call and surfing in such cases I had received near about 5-6 hours of life .
  17. Jan Engelhardt
  18. G_Aditya_Raj_uKPL
    Donut Jul 20, 2017
  19. G_Aditya_Raj_uKPL
    Donut Jul 20, 2017
  20. pablofg1978
    Head Moderator Head Moderator Jul 20, 2017
