Battery/Charger Problem
  1. G_Brahmjeet_Tanwar_CRzR
    Eclair Mar 25, 2017
    G_Brahmjeet_Tanwar_CRzR , Mar 25, 2017 :
    hello guys, i have been searching for a while about the issues and can't decide whether my battery is not good or charger. what should i do in this case? and i searched alot on Amazon.in to get the new original battery but can't find it. please help.
  2. pjshivam14
    Gingerbread Mar 25, 2017
  3. Satwik Shetty
    Cupcake Mar 27, 2017
  4. nikhilanroid7
    Gingerbread Mar 27, 2017
  5. Ravi BINAVAT
    Ice Cream Sandwich Mar 27, 2017
  6. G_Brahmjeet_Tanwar_CRzR
    Eclair Mar 27, 2017
  7. G_Brahmjeet_Tanwar_CRzR
    Eclair Mar 27, 2017
    G_shafikur_shah_XMmd likes this.
  8. G_Brahmjeet_Tanwar_CRzR
    Eclair Mar 27, 2017
    G_Brahmjeet_Tanwar_CRzR , Mar 27, 2017 :
    and if it seems out to be a battery problem then? how could i know whether it's charger or battery problem?
  9. nikhilanroid7
    nikhilanroid7 , Mar 27, 2017 :
    OS, current o/p using ampere and when you bought Oneplus2
  10. tusar8
    Jelly Bean Mar 27, 2017
    tusar8 , Mar 27, 2017 :
    Ebay.in
  11. Kumar shrijan
    Donut Mar 27, 2017
  12. G_Brahmjeet_Tanwar_CRzR
    Eclair Mar 27, 2017
    one on Amazon.in is for 400 and other one is of 500 which one should i buy
  13. G_Brahmjeet_Tanwar_CRzR
    Eclair Mar 27, 2017
  14. G_Brahmjeet_Tanwar_CRzR
    Eclair Mar 27, 2017
    3.5.8 os version.
    since i updated i m getting almost 10-12 hours battery backup and nk heating issue i mean it is greatly reduced. it's just taking 10-12 hours to get charged. i bought OnePlus 2 around 1.6 years ago
    i think now i should buy new charger?
  15. djanuj
    Donut Mar 27, 2017
    djanuj , Mar 27, 2017 :
    buy from OnePlus website. they provide original parts. but it will be expensive. sometimes stock also gets over pretty fast.
  16. ninja123456
    ninja123456 , Mar 27, 2017 :
    400 is for micro USB
    500 is for USB type c to USB 2.0
    800 is for USB type c to USB 3.0
    I had contacted mivi and they replied me with these details. I don't think 500 and 800 will make much difference as OnePlus 2 didn't have ufs or done super internal storage hardware. the charging speed for the 2 and 3 remains same only the transfer speed varies little
  17. ninja123456
    when phone sales goes down something has to go up right? when contacted OnePlus the first thing they told me was to get the adapter and cable checked at service centre, as the phones warranty was down the drain they told me to change the duo. well these kinds of problems can be created by planting battery charging and discharging bugs intentionally. the other reason is to make users notice the difference between the old and new piece of junk.
    a smart move will be to make a backup of oxygen OS and fresh install lineage os or resurrection remix os
  18. nikhilanroid7
    Can you check current flow..
    Dail *#808# it will open manual test scroll down click on charger..
    Check while charging only
  19. Ts Vilasini
  20. Kumar shrijan
    Donut Mar 27, 2017
    Kumar shrijan , Mar 27, 2017 :
    I had the same issue. So i asked the mivi people and they said that the difference between the two is that 500 one will have faster data transfer rate when you connect it to the laptop or anything.
    I went for the 400 one and it works brilliant. More than i expected.
