Battery charging issues via OnePlus 8 Pro
  1. DrHuda
    Gingerbread Jan 21, 2022
  2. Gor.
    New Star of Community Award 2021 Jan 21, 2022
    Gor. , Jan 21, 2022 :
    Hey there,
    • Hope you're using the official charger and USB cable. If yes, try another brick and USB cable if possible to charge the phone and see if issue persists.
    • Disable optimized charging and see if it helps.
    • Clean the charging port and the USB cable's type C port from any present dust particles
    • Try another wall socket and see if it the problem still persists
    Ahm, okay.
    You shouldn't be reluctant to update. They include fixes for such cases and who knows may also improve phone performance.
    What other bugs please if I may ask. Being clear can help in determining potential solutions :).
    In conclusion, check out the following thread for further tips and suggestions on charging and more. You can also discuss your case there with other users and come to a workable solution.
    drl431 likes this.
