battery charging
  1. WiLd么AKAY
    Donut May 31, 2019
    WiLd么AKAY , May 31, 2019 :
    i have OnePlus 7 pro and my problem is that it takes 1 hr 38 minutes to charging 0 to 100
    please share your feedback
  2. Praty_28
    KitKat May 31, 2019
    Praty_28 , May 31, 2019 :
    Warp charge only works till 0-70% after that the charging speed is significantly reduced to prevent the battery from degrading.
  3. WiLd么AKAY
    Donut May 31, 2019
    oh really...
    it takes 0-35% in 20 minutes and after 70% its slowly
  4. Praty_28
    KitKat May 31, 2019
    Yes that's normal if you are using the phone while charging, if your phone is idle with screen off, it should charge from 0-45% in 20 mins, also it should take approximately 1 hour 20 mins to full charge if its idle while charging.
  5. WiLd么AKAY
    Donut May 31, 2019
    i m charging to mobile in switch off condition
    when charging to switch off condition it take 0-35 in 20 minutes and 50 in 30 minutes
    and fully charge it takes around 1hr 40 minutes
  6. Praty_28
    KitKat May 31, 2019
    Thats its not normal, try changing the socket. You are using the charger and cable provided in the box right?
  7. Rahstyles
    Gingerbread May 31, 2019
    Rahstyles , May 31, 2019 :
    Which is dumb... because I think most of us.. Especially me buy a phone every 6 months... So if it degrades a little.. thats perfectly fine.. I rather have it fast charging 0 to 100
  8. Gupts007
    Froyo May 31, 2019
    Gupts007 , May 31, 2019 :
    Agreed this warp charging is merely a fancy term to attract people. Previous dash chargers on prior generation of OP's were much faster.
    I timed the charging today and realised the charge to time factor is 1.5 upto 80% level. So in 30min expect around 45% charge. Beyond that it slows down.
    Ofcourse this has a bigger battery so will take more time to juice up but then the charging wattage is also higher so the time should have been reduced or atleast be the same compared to 6T.
    A string of disappointments (pathetic camera & poor battery life) for me with this purchase but since now I own it I will have to pretend to love it.
    F_Ashok_Saraswat_Crud likes this.
  9. WiLd么AKAY
    Donut Jun 1, 2019
    WiLd么AKAY , Jun 1, 2019 :
    ryt
  10. The fraggle
    Froyo Jun 1, 2019
    The fraggle , Jun 1, 2019 :
    I'm a little confused by people complaining about your phone fully charging from completely dead in under an hour and forty minutes.....
    I think some people need to look at their priorities in life.....
    Leathermonkey7 likes this.
