battery consumption is very more after November update.
  1. R1572017267738
    Eclair Dec 17, 2019
    danishmemon likes this.
  2. kinghaloman
    Ice Cream Sandwich Dec 17, 2019
  3. xnutzii
    Lollipop Dec 17, 2019
    xnutzii , via OnePlus 6T , Dec 17, 2019 :
    clearing cache does nothing on 7T.
    Besides, clearing cache if it's there, it'll only slow the phone down and drain battery.
  4. R1572017267738
    Eclair Dec 17, 2019
    R1572017267738 , Dec 17, 2019 :
    I didn't clear cache
  5. danishmemon
    Gingerbread Dec 17, 2019
    R1572017267738 likes this.
  6. kinghaloman
    Ice Cream Sandwich Dec 18, 2019
    kinghaloman , via OnePlus 7 Pro Nebula Blue , Dec 18, 2019 :
    maybe for a little bit. But yes while in newer versions of Android they got rid of the cache partition, apps still store cache. Go through them one by one, or use for example googles file app on the play store.
  7. xnutzii
    Lollipop Dec 18, 2019
    xnutzii , via OnePlus 6T , Dec 18, 2019 :
    And again - slow down the phone by doing so, and only consuming more battery, plus, the cache partition that you can clear in recovery is useless, because there ain't none.
    Read more here: https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
  8. kKoI1233
    Gingerbread Dec 19, 2019
  9. kinghaloman
    Ice Cream Sandwich Dec 19, 2019
  10. xnutzii
    Lollipop Dec 19, 2019
    xnutzii , via OnePlus 6T , Dec 19, 2019 :
    Obviously, but no need to tell if there is only a negative impact anyway.
  11. kinghaloman
  12. xnutzii
    you hopefully know I'm not the one that opened the thread?
  13. kinghaloman
    kinghaloman , Dec 19, 2019 :
    Yeah I was just speaking in third person, as in someone is already having battery issues, why worry about a little extra drain if it could maybe fix the issues
  14. xnutzii
    most probably won't fix it.
    I mean, I shared a thread where myths about cache are busted.
  15. kinghaloman
    kinghaloman , via OnePlus 7 Pro Nebula Blue , Dec 19, 2019 :
    but usually, if the system itself is fine (which for most people it is) then it's usually a rogue app
  16. xnutzii
    no doubt.
    but uninstalling should work better
  17. kinghaloman
  18. R1572017267738
    Eclair Dec 21, 2019
