battery consumption via OnePlus 5T
  1. ratnak
    Eclair May 29, 2020
    ratnak , via OnePlus 5T , May 29, 2020 :
    after updating it to android 10,there is huge battery consumption. even if he keep the phone idle it is draining. pls fix in next update.
    and also side gesture is some what not stabilized . if we use gmail app ,if we went want to drag the side bar, it is closing the app because of side back gesture. so pls look into this also. thanks
  2. Waveform Modifier
    Marshmallow May 29, 2020
    Waveform Modifier , May 29, 2020 :
    1. This is a user community forum and not support. No one here will "look into" anything for you. You either report issues properly to the appropriate location or you fix it yourself.
    2. Android 10 is a major update, bigger battery consumption is to be expected.
  3. ratnak
    Eclair May 29, 2020
  4. Dresa91
    User of the Year 2016 May 29, 2020
    Dresa91 , May 29, 2020 :
    why do you have to create a second, identical thread?
    https://forums.oneplus.com/threads/battery-consumption.1232610/
    Tobikage likes this.
