Battery discharge via OnePlus 6T
  1. Sagar78
    Eclair May 4, 2020
  2. Artemus.
    Nougat May 4, 2020
    Artemus. , May 4, 2020 :
    That depends. If it drops to 95% within a few minutes with no usage, this is completely normal. There's a reason there are those who say to charge it to 80% as this is the "best spot".
  3. frshboxx
    Gingerbread May 4, 2020
  4. O1586331550560
    Eclair May 4, 2020
    O1586331550560 , May 4, 2020 :
    Message of increase battery discharge during starting means battery is unable to give enough cranking amps.reason could be low charge on battery or poor battery connection.👍
  5. Sandeep Thapliyal
    Eclair May 4, 2020
    frshboxx likes this.
  6. Sandeep Thapliyal
    Eclair May 4, 2020
  7. Sandeep Thapliyal
    Eclair May 4, 2020
  8. Luc_B
    Cupcake Aug 19, 2020
  9. Luc_B
    Luc_B , Aug 19, 2020 :
    but my battery was on 33% and drop to 20 % on one night normally It's losing like 3-4%
  10. ItsRavi25
    Ice Cream Sandwich Aug 19, 2020
    ItsRavi25 , via OnePlus 6T , Aug 19, 2020 :
    You can calibrate to enhance your battery life
    For battery draining you should follow this to calibrate..
    Goto settings >App and notifications>Click on three dot in right corner>Reset app preference.
    To Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Thanks to @Caomhin 😇...
    Artemus. and Caomhin like this.
