Answered battery drain 5T
  1. Kashonline
    Donut Jul 24, 2018
    Kashonline , Jul 24, 2018 :
    I have had an amazing battery life before. battery life on my 5T is way way down now. I almost charge it twice or thrice a day. I have deleted all the most ram taking apps but still the same. I started using a Mi Band 3 so, my Bluetooth is always on( turned off the discoverable option). my mobile data is turned on most of the time.I have even turned off the location services. but nothing has changed.
  2. karfa.sankha
    Eclair Aug 14, 2018
  3. Gav_W86
    Moderator Moderator Aug 14, 2018
    Gav_W86 , Aug 14, 2018 :
    Check out the existing pinned thread about battery life tips and info.
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    If necessary you can post your battery life stat screens from settings there.
  4. B1542969974909
    Cupcake Nov 23, 2018
    B1542969974909 , Nov 23, 2018 :
    option is to take all the smartness out (disable everything) from the smart phone and use, that's what OnePlus recommend for more battery life !
  5. Gav_W86
    Moderator Moderator Nov 23, 2018
    Gav_W86 , Nov 23, 2018 :
    battery use depends on your use, what apps you have installed, and what settings/services are running.
    what do the battery use screens in settings say is using your battery?
    best to look after a full (100% to <10%) single charge use for best info.
    you can post screenshots here if you need assistance interpreting.
  6. B1542969974909
    Gav_W86
    best to look after a full (100% to you can post screenshots here if you need assistance interpreting.
    idle overnight also.batter drains with data off.
    11:20pm it was 75% and 5:45 am shutdown. no usage idle without data.
    been using phone from 8 months with same apps and services , but facing issue only from past 3 days.
