3
Battery/Charging Battery Drain After Google Duo Integration Update!
  1. G_Mohnish_Sen_BkFL
    Donut Feb 16, 2019
    G_Mohnish_Sen_BkFL , Feb 16, 2019 :
    I've been facing battery drain after the google duo deep integration update!
    It's irritating, 1% every 2 minutes, no matter the app!
    cas8180, sir1jaguar and robin143 like this.
  2. RengelG8
    Gingerbread Feb 16, 2019
  3. G_Mohnish_Sen_BkFL
    Donut Feb 16, 2019
    no, and why to do that?
    I'm a new Android user
    sir1jaguar likes this.
  4. RengelG8
    RengelG8 , Feb 16, 2019 :
    well, after updates some cache data are incompatible with the new version and can produce some issues mostly in battery. so, you should create a security copy of your data like photos, ... then, you update and after the update you turn off the phone. you turn on in recovery mode to delete all the cache and data and then, turn on normally. So, you will lose the data of your phone but the phone normally works well. It's not necessary to do this in every update, just big updates. battery performance will improve with time and charge cycles. calibrate the battery could be an option too.
    G_Mohnish_Sen_BkFL likes this.
  5. robin143
  6. robin143
    Gingerbread Feb 17, 2019
    robin143 , Feb 17, 2019 :
    facing heaving battery drain and heating for a small usage in 9.0.4.
    9.0.3 have no issues in it. After updating to 9.0.4 this problem occurs. Also doneClearCache
    9.0.2 was having such issues , after updating to 9.0.3 , all battery problem and heating issue solved. Now again distracting customers because of issues in 9.0.4.
    Now I am afraid to software update my device.
    I request you to solve this issue with next update .
    Pls provide only stable updates , otherwise dont release the update
  7. bpwest80
    KitKat Feb 17, 2019
  8. G_Mohnish_Sen_BkFL
    Donut Feb 17, 2019
    G_Mohnish_Sen_BkFL , Feb 17, 2019 :
    Still it has the same problem
    i rebooted into recovery mode
    and charged it fully
    now that same thing of each app takingb1% battery just for 1-2 min of use!
  9. bpwest80
    KitKat Feb 17, 2019
    bpwest80 , Feb 17, 2019 :
    You're kidding right? If you use an app it's gonna use battery. Do you people expect the phone to last two weeks at a time? If you figure out how to use an app without the app using battery let me know.
  10. G_Mohnish_Sen_BkFL
    Donut Feb 17, 2019
    That i know and i understand that
    but this thing started right after the new update
    this wasn't the situation before!
    like for every 1-2 minutes?!
    robin143 likes this.
  11. Android450
    Marshmallow Feb 17, 2019
    Best Answer
    Android450 , Feb 17, 2019 :
    Plug your phone in overnight before you go to bed you should be good by morning The update needs to optimize and the process only begins when the phone is plugged in and isn't used for a few hours
    Bobbie63 and G_Mohnish_Sen_BkFL like this.
  12. bpwest80
    KitKat Feb 17, 2019
    Your battery graph looks alright to me. I don't see anything out of the normal. Good luck to you though.
  13. robin143
    True
  14. robin143
    Facing same problem ..
  15. G_Mohnish_Sen_BkFL
    Donut Feb 17, 2019
    After two charge cycles, my phone's battery is working perfectly fine now!
    it's just sometimes we expect more than required
    and we feel disappointed!
    rarog and Android450 like this.
