battery drain after new update one plus 6 os 9.0.7
  1. O1539159759322 Cupcake Jul 9, 2019
    O1539159759322, Jul 9, 2019 :
    am rapid user off one plus since when phone launched,
    even device started to heat up.till now had no issue at all.am one plus 6 is my gaming device .used to give good battery over heavy uses
    but after update started to drain battery..
    todya for just using WhatsApp for an hour took my 20 perc battery.
    last night itz was 10 perc battery which last upto 1 hour using WhatsApp.
    seriously started to drain battery after update.please solve this issue.
  2. B_Wrath Marshmallow Jul 9, 2019
    B_Wrath, Jul 9, 2019 :
    When did you update your phone?
  3. O1539159759322 Cupcake Jul 9, 2019
    Friday most probably after the update one restart for update finished.today phone got switched off morning.after that I felt battery drain.
    I regularly hear gaana app on this phone.while traveling to job.
    I start wit 97 perc battery when I reach office this Bes around 89 perc which is perc .
    but today I did not used gaana only WhatsApp but it drained till 80 perc.n after update while playing hd games phone started to heat.
    I use gaana app and other app simultaneously everybday but still the battery backup was awesome.but today onli using WhatsApp and a huge amount of battery drain.
  4. JustAPhone Ice Cream Sandwich Jul 9, 2019
    JustAPhone, Jul 9, 2019 :
    yup... having the same problem.... leave it over night.. at 45%.... woke up and no more power.
    Factory reset 2 days ago... and looks ok for now...
    ironass likes this.
  5. M1556951592124 Cupcake Jul 9, 2019
  6. ChristinaHS Cupcake Jul 11, 2019
  7. ironass KitKat Jul 11, 2019
    ironass, Jul 11, 2019 :
    A Factory Reset usually resolves most battery draining issues after an update. Shame more users do not try it. ;)
    Kytharsis and ChristinaHS like this.
  8. ChristinaHS Cupcake Jul 11, 2019
    ChristinaHS, Jul 11, 2019 :
    I will try that tonight ;). Thanks!
    ironass likes this.
  9. G_jeetu_kundnani_FyQz Cupcake Jul 16, 2019
  10. G_jeetu_kundnani_FyQz Cupcake Jul 16, 2019
    G_jeetu_kundnani_FyQz, Jul 16, 2019 :
    ironass
    A Factory Reset usually resolves most battery draining issues after an update. Shame more users do not try it.​
    Hey i have reset just phone or all data has to erased?
  11. jools54321 Cupcake Aug 13, 2019
    jools54321, Aug 13, 2019 :
    Same problem with battery drain here.
    Also problems connecting to Bluetooth headset and volume levels fluctuating
  12. M1556951592124 Cupcake Aug 15, 2019
    M1556951592124, Aug 15, 2019 :
    Anyone tried the new update if it fixing the issue ?
    I am hasitant to install it , I lost trust in their updates...
