2
[Submitted] Battery drain after recent update (Oxygen Os 10.3)
  1. Stavan.94
    Cupcake Dec 24, 2019
    Stavan.94 , Dec 24, 2019 :
    I recieved the oxygen OS 10.3 update to my 6t yesterday and ever since then battery has been draining intensely.
    before the update battery used to last ~18 hours but now it doesn't even last 12 hours after a full charge.
  2. K1577296677908
    Cupcake Dec 25, 2019
  3. Z1543176770859
    Cupcake Dec 27, 2019
    Z1543176770859 , Dec 27, 2019 :
    Same problem here, after the update the battery drains like crazy. My screen-on-time went from 7-8 hours down to 3 hours with the same useage. Also the performance went down by alot, I can't even switch between apps without clearly noticeable lag.
    I hope this can be fixed fast...
  4. MILIND.MEVADA
    Cupcake Dec 28, 2019
  5. Y1542316167524
    Cupcake Dec 30, 2019
  6. A1577833319620
    Cupcake Dec 31, 2019
  7. Kennebunk Larry
    Cupcake Jan 3, 2020
    Kennebunk Larry , Jan 3, 2020 :
    It's January 3 and there's still no fix for this problem! Doesn't Oneplus test their new releases before releasing them as a stable version? I'm going on vacation and will need a long duration battery charge.
  8. T1532890331334
    Cupcake Jan 8, 2020
  9. B1541572304211
    Cupcake Jan 13, 2020
    B1541572304211 , Jan 13, 2020 :
    After oxygen os 10.3 my screen on time went from 7 hrs to 3 hrs..this is really bad..it would have been better if they had tested and then provided the update..
  10. A1577833319620
  11. Roberto.T
    Cupcake Jan 14, 2020
    Roberto.T , Jan 14, 2020 :
    I can confirm the issue. The drain is pretty massive and it's especially noticeable overnight. The same problem affects the OP6.
  12. H1583429193419
    Cupcake Mar 5, 2020
    H1583429193419 , Mar 5, 2020 :
    Me too ☹️
    I wish I never got the update. Both the one and the one in December. This have ruined my phone!!!
    #OnePlusUpdateRuinedMyPhone
    Power is drained in less than a day, before it could hole power for two days without any problems.
    Please get this problem fixed OnePlus.
    /Torben
