6
Battery drain after updating to OxygenOs 10.0.1 (Oneplus 6) via OnePlus 6
  1. Podihetti27
    Donut Dec 9, 2019
    Podihetti27 , via OnePlus 6 , Dec 9, 2019 :
    (This Screenshot is not mine because I just opened my phone and I don't have any battery details to provide for the meantime?
    I update my phone to android 10 4 days ago and I am seeing a vast change of battery draining...it seems that Google play services, OnePlus launcher and whatsapp is using a significant amount of battery even though I'm not using it very much....I'm already regretting updating my phone to this version but the new features are remarkable.Hope oneis fixes this fast...until then any solutions or tips that I should follow guys ?
    oh and also my keyboard has gone a bit up
    Thank You
  2. Artemus.
    Nougat Dec 9, 2019
    Artemus. , Dec 9, 2019 :
    WhatsApp is notoriously battery-hungry and FB doesn't care to optimize it very well, I suggest getting rid of it unless you absolutely need it. As for the keyboard, this is by design.
    Caomhin likes this.
  3. Dipankardeori1plus6
    Cupcake Dec 9, 2019
  4. lalitbanker
    Eclair Dec 9, 2019
    Podihetti likes this.
  5. lalitbanker
    Eclair Dec 9, 2019
  6. Artemus.
    Nougat Dec 9, 2019
    I offered both.
    Caomhin likes this.
  7. DragonRider007
    Donut Dec 9, 2019
    DragonRider007 , via OnePlus 6 , Dec 9, 2019 :
    Facing the same issue on mu Oneplus 6 running 10.0.1
    Although the features introduced is amazing, I regret upgrading as the 🔋 drain is huge which does not even lasts for half a day.
  8. angelitusss
    Eclair Dec 9, 2019
  9. VDS1997
    Donut Dec 15, 2019
    VDS1997 , Dec 15, 2019 :
    same is happening with my device even some of my apps are freezing for 2-3 seconds after this update
    W1549314847361 and Podihetti like this.
  10. ABHI177
    Froyo Dec 15, 2019
    Caomhin likes this.
  11. rajatag03
    Donut Dec 15, 2019
  12. Caomhin
    Marshmallow Dec 15, 2019
  13. p51d007
    KitKat Dec 15, 2019
    p51d007 , Dec 15, 2019 :
    For those having issues with 10.x
    1. Was this an OTA update?
    2. Did you use the Oxygen updater to update to 10?
    If 1 is yes, get on the official OP support forums, not here.
    If 2 is yes, then, well, it's your own fault.
    It's why 10 has been SLOWLY rolled out...it still has issues!
  14. Z1557616435569
    Donut Dec 16, 2019
  15. manasarora98
    Ice Cream Sandwich Dec 16, 2019
    manasarora98 , via OnePlus 6 , Dec 16, 2019 :
    Brother, I would suggest a complete reset of Phone(after backup) and connect to a high speed wifi update everything apps from Playstore and OnePlus Software Updates .
    Wait for 7 days and then check with the battery usage of the phone.
    Usually for first few days, everything tries to consume a lot of battery for new update and Android setup.
    Post a review or message me if this helped after 7 days of setting up the phone again
  16. BigM
    Gingerbread Dec 16, 2019
    BigM , Dec 16, 2019 :
    I also experience a massive battery drain on my OP6 after updating to 10.0.1.
    Usually battery life gets worse after updates, but normalizes after a few days. Seems like the System needs some time to calibrate battery again after an update.
    But this time the Update is a week ago and battery is still draining extremely fast.
    I have also drained the battery to 0 % several times and charged it overnight. This did not change anything.
    I have cleared cache, but this did not change anything.
    There is also no explicit app in battery stats that draws much battery life. It just seems everything uses way more power than before.
    Any solutions, yet?
    ianudeep97 and Podihetti like this.
  17. VDS1997
    Donut Dec 16, 2019
    VDS1997 , Dec 16, 2019 :
    This my statistics of my OnePlus 6 batt, hope oneplus listens to this and give us a fix soon for device, it would really be appreciated
  18. Caomhin
    Marshmallow Dec 16, 2019
    Caomhin , via OnePlus 6T Mirror Black , Dec 16, 2019 :
    If a particular app is doing that, optimize the app in Battery optimizer. Also clear the cache on the offending app. Also check if there is an updated version of that app available.
  19. BigM
    There's no app in particular that uses very much battery. please see attached screenshot. I really don't know what consumes all the power.
    I even did not use my phone very much since last recharge.
    Before the Update I could use my phone for about 24 hrs, now it's down to about 14 hrs.
    Also, I activated battery optimization for all apps.
  20. Caomhin
    Check your SOT, mu SOT is 1 hour 13 mins, see screenshot below. Also click the 3 button option top right and show system apps, full device usage in the drop down, see if there is a culprit in there.
