2
Battery drain and heating up - OP3T
  1. abhirup0911
    Donut Nov 8, 2017
    abhirup0911 , Nov 8, 2017 :
    My battery life has deteriorated over the past six months. No amount of updates nor following the community suggestions has helped in any way. My SOT is 3.5hrs and the whole battery drains by around 8 hours. Add to that it is heating up like the OP2 while charging and gaming. I was extremely happy for the first 2 months when the battery was lasting for almost 1.5 days and then deteriorated rapidly. Help if you can!
  2. G_Steven_oOCJ
    Gingerbread Nov 8, 2017
    G_Steven_oOCJ , Nov 8, 2017 :
    3.5 is pretty good in my opinion, heating up while charging and gaming ? ain't that supposed to be normal ?
    abhirup0911 likes this.
  3. samsou8803
    Froyo Nov 8, 2017
    samsou8803 , Nov 8, 2017 :
    try to do a factory reset. may be some app you installed draining your battery.
    worst case , you have to change your battery. if it's still under warranty , go now.
  4. abhirup0911
    Donut Nov 8, 2017
    See. I know it's normal. Any phone normally gets warm. but mine is becoming hot. Can be sensed almost close to causing a burn.
  5. G_Steven_oOCJ
    well it's made of metal so I assume it's normal . mine get real hot too
  6. abhirup0911
    Donut Nov 8, 2017
    I've done that. It didn't work. same issue.
  7. abhirup0911
    Donut Nov 8, 2017
    See. I've used OP2 before OP3T. that's why gave the comparison. OP3T never reaches as high a temperature as the OP2. Mine is behaving oddly I think :(
  8. samsou8803
    Froyo Nov 8, 2017
    check with service center then asap if you have warranty .I now days battery issue is very common.
    btw which application took the max juice out of your phone?
  9. Scherpenseel
    KitKat Nov 8, 2017
    Scherpenseel , Nov 8, 2017 :
    If none of the community suggestions helped, then why are you here? There are already hundred of tips for battery drainig solutions.
  10. abhirup0911
    Donut Nov 8, 2017
    The first two are Android System and Screen. But the drain happens even when it's on standby. I've tried keeping it on Airplane mode. But even then the drain happens even on the slightest of use.
    Yes, it's within warranty. I bought it in February 2017.
  11. Catalin_Buzescu
    Jelly Bean Nov 8, 2017
    Catalin_Buzescu , Nov 8, 2017 :
    Can u please tell us, one by one, which measures did you take in solving the battery draining issue?
  12. abhirup0911
    Donut Nov 8, 2017
    Haven't lost faith yet. :)
  13. G_Steven_oOCJ
    mine get really hot, to the point when I charge my phone I take off my case so yeah , I don't think your is behaving oddly
  14. samsou8803
    Froyo Nov 8, 2017
    Ok. I had one plus one for 4 years then I switch to five.
    for my previous experience regarding battery issue solve by below way, if battery is not faulty.
    how to clear cache and give hard reboot?
    1. turn off your phone.
    2.press power and down volume together for 3 to 5 sec, until boots as recovery mode.
    3. scroll and select wipe data and cache
    4. next select wipe data and then select yes.
    as your phone is under warranty, you can go to service center and asked them to do it for you.
    if still you not able to it. let me know I will explain again when I have log in via laptop. [e]1f609[/e]
  15. abhirup0911
    Donut Nov 8, 2017
    1. Cleared cache through settings.
    2. Wiped cache through recovery.
    3. Did factory reset.
    4. Facebook was being shown as the hogger, had uninstalled it.
    5. Switched off automatic backup.
    6. Cleared Google Play Services.
    7. Aggressive doze and hibernation on.
    8. Wiped cache and partition and then did factory reset.
    samsou8803 likes this.
  16. samsou8803
    Froyo Nov 8, 2017
    share the links then. it will help him. your replay is not helping anyone.
  17. Catalin_Buzescu
    Fair enough. :))
    In your case I would try clean install of a previous version of OOS. Last ditch
