3
*** BATTERY DRAIN FINAL FIX 4.0.2 ***
  1. dipta.ds Honeycomb Jan 21, 2017
    dipta.ds, Jan 21, 2017 :
    We are talking about the OP2 here. Go to the OP3/3T forum and express your views there
    #41
    akhil sivakoti likes this.
  2. akhil sivakoti Cupcake Jan 21, 2017
    akhil sivakoti, Jan 21, 2017 :
    Excuse me..
    #42
  3. akhil sivakoti Cupcake Jan 21, 2017
    #43
    dipta.ds likes this.
  4. G_raymond_gonzalez_zCym Cupcake Jan 21, 2017
  5. dipta.ds Honeycomb Jan 21, 2017
    #45
  6. G_mustafa_khadkiwala_CHe Donut Jan 21, 2017
    #46
    G_T._A._CxNO likes this.
  7. ritchiedrama Ice Cream Sandwich Jan 21, 2017
    ritchiedrama, Jan 21, 2017 :
    I said they don't require location. Which they don't you can use it if you want but it isn't a necessity.
    #47
  8. remedy KitKat Jan 21, 2017
    remedy, Jan 21, 2017 :
    Switch off the phone when you are not using it.
    #48
  9. G_T._A._CxNO Gingerbread Jan 21, 2017
    G_T._A._CxNO, Jan 21, 2017 :
    you guys are right. It makes no sense, saying one have to disable this and that for better battery life.
    If a car starts burning after driving for 5 minutes, then you have to solve the burning issue.
    "So just drive 4 minutes and switch off lights and radio" is not a solution. Especially when the car was expensive.
    #49
    Mitsu71 and bpwest80 like this.
  10. marcocartella Gingerbread Jan 21, 2017
  11. Ian_F Gingerbread Jan 21, 2017
    Ian_F, Jan 21, 2017 :
    Your title is very misleading. It is NOT a final fix. In fact it is not a fix at all.
    But hey, it got my attention so am sure it'll fool others too.
    #51
    crysen and F_Tony_DeMartino_hjHI like this.
  12. F_James_Sotheran_jOGq Cupcake Jan 21, 2017
    #52
  13. SurajLoharia Jelly Bean Jan 21, 2017
    SurajLoharia, Jan 21, 2017 :
    Try not to lit all lights to get low bill
    Your opinion.
    #53
  14. Meltzer Cupcake Jan 21, 2017
    Meltzer, Jan 21, 2017 :
    I had this issue, solved it by deleting updates of Google play services (Settings -> Apps -> Google play services -> Delete updates), and installed new one from play store. No more battery drain.
    #54
  15. G_rama_subbaiah_VjOo Cupcake Jan 21, 2017
    #55
  16. F_Tony_DeMartino_hjHI Ice Cream Sandwich Jan 21, 2017
    #56
  17. F_Tony_DeMartino_hjHI Ice Cream Sandwich Jan 21, 2017
    #57
  18. Ian_F Gingerbread Jan 21, 2017
    It was just to get his post count up. The full horror of his experiences can be found in his new thread.
    #58
  19. F_Tony_DeMartino_hjHI Ice Cream Sandwich Jan 21, 2017
    F_Tony_DeMartino_hjHI, Jan 21, 2017 :
    I saw. His experience is not everyone's experience so like I said it's a bit overboard.
    #59
  20. bpwest80 KitKat Jan 21, 2017
    bpwest80, Jan 21, 2017 :
    True. But I use location service set to battery saving and it really doesn't use that much battery at all. I'm sure if it was turned completely off that battery life would improve but that's just something I can't do.
    #60
