115
Battery drain fix - update
  1. safadi
    Gingerbread Aug 15, 2014
    safadi , Aug 15, 2014 :
    A lot of apps consuming data.
  2. toppertje
    Honeycomb Aug 15, 2014
    toppertje , Aug 15, 2014 :
    Thanks for the info!
  3. Pallec
    Froyo Aug 15, 2014
    Pallec , Aug 15, 2014 :
    I am on 7 hours 30 minutes with 81% left. Have used the phone quite a lot during that time.
  4. medellin
    medellin , Aug 15, 2014 :
    Thanks, If disable, and gesture disable, the sensor is off?
  5. alarge
    Donut Aug 15, 2014
    alarge , Aug 15, 2014 :
    This has now been marked as resolved on the bug tracker pending a successful run on the test suite.
    After that it will be an expedited OTA. Just be patient.
    xf4d3 likes this.
  6. ufomania
    Ice Cream Sandwich Aug 15, 2014
  7. tjb50
    tjb50 , Aug 15, 2014 :
    I searched the forum for info about nightlies, how to install- couldn't find what I needed so I'll ask here.
    I do NOT have a rooted OPO, can I still install nightlies via recovery console?
    Or must OPO be rooted in order to install nightlies.
    Thanks!
  8. Innomi
    Innomi , Aug 15, 2014 :
    Rooted and custom recovery like twrp or cwm
    There is a detailed thread here on opo forum. I have seen it.
  9. medellin
    with no proximity sensor it's better
    only 4 % lost in 3h17min (with wifi, telecom,...)
  10. bert003
    Cupcake Aug 15, 2014
    bert003 , Aug 15, 2014 :
    I remember trying an app called 'Proximity screen off' to wake-up my Samsung S3 when opening the flipcover. It worked, but the proximty sensor was kept on, which I could see because it gave a very little light shining. The downside of this app was the battery life decreased by 50%.
    So I would not be surprised if this turns out to be the same problem with the Oneplus.
    Happily we wil get an update for this. I didn't had any unwanted wakeups since I use the flipcover on my One.
  11. nkodrobbo
  12. cbendan
  13. XmXmaks
    KitKat Aug 15, 2014
    XmXmaks , Aug 15, 2014 :
    Awww yiiiss, thank you good sir for the update. Really glad they are on the ball with this stuff.
  14. dayanandgp
    dayanandgp , Aug 15, 2014 :
    Faced the same issue...Proximity sensor staying on , only a reboot fixed it :-(
  15. Dkouyou
    Dkouyou , Aug 15, 2014 :
    Woke up this morning and saw it was resolved, pretty happy! OTA very soon:)
    need-oneplus likes this.
  16. generalkipper
    Froyo Aug 15, 2014
  17. friss
    friss , Aug 15, 2014 :
    Thanks for the uodate info, Waiting for new OTA to fix the bug. Wondering why my battery drain so fast as compared to the previous version. Did CM Team test before rollout, they should detect this issue before releasing an OTA. LOL
  18. cescrey
  19. natibaquet
    jlasensiofi likes this.
  20. keenez
