Battery drain in one plus 5..,
  1. barath_000
    Gingerbread Jun 25, 2017
    barath_000 , Jun 25, 2017 :
    I seeing huge battery drain in one plus 5, last night it drained more than 30%of battery.., I think it not going to deep sleep mode..,
    rezor92 likes this.
  2. pappujaiswal
    Cupcake Jun 25, 2017
    pappujaiswal , Jun 25, 2017 :
    as per launch event, battery is draining very much fast. not matching the word with CEO at launch event.
  3. Jjallday
    Jjallday , Jun 25, 2017 :
    yeah I'm dropping about 30% from 100% in 30mins while not even using the phone with no apps in the background.... while using the phone I can barley get a solid hour and a half before battery is almost dead. idk what the deal is
  4. vik45
    Honeycomb Jun 25, 2017
    vik45 , Jun 25, 2017 :
    one plus 5 stills lacks the best software tweaks..[e]1f602[/e][e]1f602[/e] design sucks too
  5. meatandy
    Oreo Jun 25, 2017
    meatandy , Jun 25, 2017 :
    Did you guys put any apps on your devices?
    Facebook could be the culprit.
    :rolleyes:
    Akhshay Srinivasan likes this.
  6. crazycarl
    Ice Cream Sandwich Jun 25, 2017
    crazycarl , Jun 25, 2017 :
    Think you got a dud bro, get on the RMA hommie or juat never turn it off apparently it's getting around 4 hours of on screen time so keep it on maybe
  7. barath_000
    No..,
  8. bombalicious
    Froyo Jun 25, 2017
  9. vernersson
    Donut Jun 25, 2017
    vernersson , Jun 25, 2017 :
    Tried to battery optimize the apps? Snapshot from OPX but should work similar on OP5.
  10. hatari
  11. MrPuma
    MrPuma , Jun 25, 2017 :
    Guys, if you are using the phone for 1-2 days it will be draining over night. On my phone it looked the same in the first night, as many apps were syncing in the background. Google Photos synced, Android synced the backup etc.
  12. Markosz
    Donut Jun 25, 2017
    Markosz , Jun 25, 2017 :
    I don't have this problem. My phone drained only 8% during the night. Wifi on, all the basic apps I need installed, etc...
  13. G_ramesh_krishna_GhRE
    Cupcake Jul 2, 2017
    G_ramesh_krishna_GhRE , Jul 2, 2017 :
    my battery drains at a rate of 4% per half an hour when I use Facebook and other social media.(i have 20 apps installed and I don't play any games)does anyone have same problem?
  14. G_Pratima_Singh_Xupk
    Donut Jul 2, 2017
    G_Pratima_Singh_Xupk , Jul 2, 2017 :
    when I watched a YouTube video for 15 min with 360p , I lost 5% of battery in one plus...can anyone say is this a issue or not?
  15. G_Pratima_Singh_Xupk
    Donut Jul 2, 2017
    y do you think this as a problem ? This is good ri8 , it's offering more battery life.
  16. G_ramesh_krishna_GhRE
    Cupcake Jul 2, 2017
    if I play games then battery will drain at a higher rate right?and I am using my OP5 With 15% brightness only.actually I expected more battery life from one plus .
  17. G_Nitin_Patil_gQMJ
    Cupcake Jul 2, 2017
  18. F_CA_Hetvi_Khatadia_WiRm
    Cupcake Jul 2, 2017
    F_CA_Hetvi_Khatadia_WiRm , Jul 2, 2017 :
    yeah the same issue I faced.. without using phone overnight it drains out 30%.. it's v serious issue f battery as it has special designed charger. not possible to carry everywer.. I think there should be some solution else need to return it
  19. mdzuhaib
    Gingerbread Jul 2, 2017
  20. anupam7860
    Cupcake Jul 2, 2017
    anupam7860 , Jul 2, 2017 :
    this might be happening because of WiFi..i have noticed battery is draining fast on WI-FI.So just try to check om network..i am getting way battery backup on 4g
