16
Working battery drain in OnePlus 7 Pro after Android 10 update
  1. bharathsharma007
    Donut Oct 20, 2019
    bharathsharma007 , Oct 20, 2019 :
    while in android 9 I used to get nearly 7 hours of screen on time in my op7 pro.. but now after the android 10 update I'm getting upto only 4.5 hours of sot
    Adz0612, kkthecow, noahG30 and 13 others like this.
  2. S1571572904806
    Cupcake Oct 20, 2019
  3. Th14g0ST
  4. T1565804567241
    Cupcake Oct 21, 2019
    F1568409198851 likes this.
  5. Mixalis90
    Donut Oct 21, 2019
    Mixalis90 , via OnePlus 7 , Oct 21, 2019 :
    OnePlus 7 consumes more battery with Android 10 than 9. I don't know if it is normal as the optimizer is been trained but for now I get the 50-70% screen of time than before.
  6. KIRAN_G_PARMAR
    KIRAN_G_PARMAR , via OnePlus 7 , Oct 21, 2019 :
    Same problem is here also
  7. amitsubhashjain
  8. Z1564159206657
    Cupcake Oct 23, 2019
  9. Gav_W86
    Starting Point Expert Oct 23, 2019
    Gav_W86 , Oct 23, 2019 :
    What are the battery use screens in settings say is using your battery?
  10. Th14g0ST
  11. shree2325
    Donut Oct 24, 2019
    shree2325 , via OnePlus 7 Pro , Oct 24, 2019 :
    I am facing the same issue since the 10 update. this is happening for a week now. my screen refresh is set to 60hz and res to dynamic.
    need assistance
  12. Prasann_Purwar
    Cupcake Oct 25, 2019
  13. yogsofter
    Cupcake Nov 1, 2019
  14. aleQ88
    Cupcake Nov 4, 2019
  15. G_Deepak_Jindal_Cfts
    Donut Nov 5, 2019
    L1558132372146 likes this.
  16. Gav_W86
    Starting Point Expert Nov 5, 2019
    Gav_W86 , Nov 5, 2019 :
    battery use depends mostly on your use, what apps you have installed, and what settings/services are running.
    what do the battery use screens in settings say is using your battery?
    best to look after a full (100% to <10%) single charge use for best info.
    you can post screenshots (both the 1st screen that says screen on time and the app use screen) here if you need assistance interpreting.
  17. Srinatha Reddy Javvaji
    Donut Nov 6, 2019
  18. Mixalis90
    Donut Nov 6, 2019
  19. Gav_W86
    Starting Point Expert Nov 6, 2019
    Gav_W86 , Nov 6, 2019 :
  20. MounicaSrinivas
    Cupcake Nov 7, 2019
    MounicaSrinivas , Nov 7, 2019 :
    Yes even i am facing this issue , i used to watch full movies and still battery used to last longer , but since Android 10 update by half day the battery is completely drained
    L1558132372146 and Andrew_18 like this.
