Battery Drain Issue in 33r (phone idle)
  1. djrasul
    Gingerbread Sep 29, 2014
    djrasul , Sep 29, 2014 :
    I've been having this issue since I updated to 33r. Anyone else out there with a similar issue?
  2. mwoolley
    Jelly Bean Sep 29, 2014
    mwoolley , Sep 29, 2014 :
    known issue mate, addressed in next software fix. you can do a search for heaps more affected users.
    CurtNwv likes this.
  3. minial1990
    Ice Cream Sandwich Sep 29, 2014
    minial1990 , Sep 29, 2014 :
    my guess is that you have low signal issues, so your phone is trying to find and hold onto a signal which is causing the drain. Are you sure you encountered the problem after the update?
    tastesawesome likes this.
  4. TakeMyMoney
    KitKat Sep 29, 2014
  5. djrasul
    Tnx for the reply.
    Im pretty sure it started after the update.
  6. tastesawesome
    Honeycomb Sep 29, 2014
  7. 1+1=0
    1+1=0 , Sep 29, 2014 :
    Hi there. Just a tip for you, I disabled double tap to wake and lock, disabled auto brightness, disabled keyboard vibration,disabled gps, disabled sync, disable 3G/4G/WIFI data when you don't need it and finally disable google play services. I know i handicapped the phone but all these features eat a lot of energy. The battery life is amazing now. If you can't disable all of them, then disable a few of them and tell me what is your result. Hope it helps. Cheers
    djrasul likes this.
  8. fgrhuhrg
    fgrhuhrg , Sep 29, 2014 :
    this is a known issue, i have it as well, but the phone can still churn out a day, so its bearable for now
  9. djrasul
    I went ahead and disabled the double tap to wake and lock. I got good results but I think it still needs to be taken care of by cyanogenmod. Thanks for the reply by the way.
  10. 1+1=0
    Happy to help. I know this because i was in the same situation when i updated to 33R. My battery life was bad. But i researched and found out how to get better life. Yes Cyanogenmod should fix these battery drain issues, hopefully in the next OTA. Fingers crossed
    djrasul likes this.
