14
[Submitted] Battery drain issue in OnePlus 7T
  1. A1571892050147
    Eclair Nov 6, 2019
    A1571892050147 , Nov 6, 2019 :
    I am facing battery drain issue in OnePlus 7T. Bought this device on 10days back, hardly i get 5hrs of SOT.
    Even i set below settings:
    Data restriction: On
    Screen resl set to 60Hz
    Using the dark theme
    Ambient display: Off
    Data saver: On
    Please refer the screenshot. Only 2hr 13min SOT on 50% battery drain with above settings.
    During night (stand by) drain almost 10% off the battery even data and wifi is off.
    Please help me on this issue.
  2. A1571892050147
    Eclair Nov 6, 2019
    B1573299684346 likes this.
  3. shubhamraj421
    Cupcake Nov 7, 2019
  4. Mohammad.shadab
    Cupcake Nov 17, 2019
  5. Suyash1122
    Froyo Nov 26, 2019
  6. Mithun Madhav
    Donut Dec 2, 2019
    Mithun Madhav , Dec 2, 2019 :
    yes i am facing the same issue .also the phone gets warm even when using youtube.
    the stand by is bad too
  7. milind.adhvaryu
    Cupcake Dec 2, 2019
    milind.adhvaryu , via OnePlus 7T , Dec 2, 2019 :
    I am also facing the same issue on my recently brought OnePlus 7T. 50% of battery drains in 6 hours of just talk time normal use. This was not the case with my earlier mobile.
  8. #8
  9. Q1575456952084
    Cupcake Dec 4, 2019
    Q1575456952084 , Dec 4, 2019 :
    I buy this ph since 2 days back
    now I'm getting 5hrs 20min SOT on normal usage, please fix this issue.
    Remaining my phone settings
    -60hz
    -dark theme
    -gps turned off
    -data restricted
    -brightness below 30%
    -all apps put on optimise settings
    PLEASE FIX THIS ISSUE
  10. P1575130125627
    Donut Dec 4, 2019
    P1575130125627 , Dec 4, 2019 :
    I purchased this phone on 30th Nov from amazon. but I found battery drianing at very fast rate.
    earlier I installed number of application.but I tested it by even after factory reset and using only YouTube..I am not comfortable with the battery performance.
    even i haven't use any sim.so battery performance is far below the expectation.
    please refer the screenshot of battery using YouTube over WiFi (post factory reset).
    also I am requesting you to please suggest how can in replacement this with good phone (as I purchased it under 10 day replacement from amazon.in)
    please help.
    A1571892050147 likes this.
  11. milind.adhvaryu
    Cupcake Dec 5, 2019
    bmwfire and A1571892050147 like this.
  12. P1575130125627
    Donut Dec 5, 2019
    P1575130125627 , Dec 5, 2019 :
    seems they are busy in selling their phone..rather than understanding customer issue or every worry to reply on thread.
    looking for quick support.
  13. A1571892050147
    Eclair Dec 17, 2019
  14. A1571892050147
    Eclair Dec 17, 2019
    A1571892050147 , Dec 17, 2019 :
    Yes I do feel the same, i guess they already know battery issue in 7T that's reason team not ready to reply this thread
  15. J1576844425838
    Donut Dec 20, 2019
    J1576844425838 , Dec 20, 2019 :
    Guys I just bought my OnePlus 7T device 2 days ago
    the device's camera,performance,software is AMAZING
    but there is one thing that is keeping me worried about
    and that is the battery life . Yes we do have fast charging which is pretty Good. But I do only get 3-4hrs of battery life it is so disappointing and because of that I need to be careful of saving more of my battery life so it can be used throughout the day . Please anyone ?? is this normal? is there a solution?
    please help :(
  16. wid.gulzar
    Cupcake Dec 20, 2019
  17. ananyr
    Gingerbread Jan 17, 2020
  18. E1579238028177
    Cupcake Jan 26, 2020
    E1579238028177 , Jan 26, 2020 :
    Battery issue is worst than i expected. It cant with stand my daily use. And i end up with 5-6% less battery on standby. It is overall a better phone with terrible battery. make our money worth a count. so please kindly fix it..
  19. P1575130125627
    Donut Jan 28, 2020
  20. Y1578849599607
    Cupcake Jan 28, 2020
    Gauravyansh and A1571892050147 like this.
