Battery drain issue in Oxygen 4.5.8
  1. G_Yogesh_Yadav_bptO
    Cupcake Aug 2, 2017
    G_Yogesh_Yadav_bptO , Aug 2, 2017 :
    my device battery is draining too quickly with minimal usage, please release next update quickly
    Edit by mod: 4.5.8 battery issues, please post in this thread.
  2. Yann Ditengou
    Froyo Aug 2, 2017
  3. rahulkr.ver
    Gingerbread Aug 2, 2017
    Luís Silvestre and rahul13nair like this.
  4. avnish.yash
    Froyo Aug 2, 2017
  5. siddiqim1990
    Donut Aug 2, 2017
    siddiqim1990 , Aug 2, 2017 :
    4.5.6 had a lot of issues on my phone. Texts failing, long lag before a call dials out. No LTE unless VoLTE turned on. Calls failing. And low reception (which can contribute to battery drain). However, I had no issues with the battery. 4.5.7 is out, I used a VPN from Canada and got the OTA. Phone works a 100 times better and has slightly better battery life so far. Try updating it.
  6. Mayurpatil155
    Froyo Aug 2, 2017
    Mayurpatil155 , Aug 2, 2017 :
    Update it to latest version 4.5.7 and if the update is not available in your country then wait for the update..
  7. rahulkr.ver
    rahulkr.ver , Aug 2, 2017 :
    but this is not fair . why wait
  8. siddiqim1990
    Donut Aug 2, 2017
    Download a VPN client from the play store. Use a Canadian VPN and then check for update. You will immediately get it.
    AshutoshShandilya likes this.
  9. G_jonny_cool_nxOr
    Jelly Bean Aug 2, 2017
    G_jonny_cool_nxOr , Aug 2, 2017 :
    No need to wait .. Just download opera vpn app and select canada region .. than go for system update and download it .. i have done it today as many people suggested me and You wont believe it Worked !! [e]1f60a[/e] .. Enjoy
  10. showstopper197
    Ice Cream Sandwich Aug 2, 2017
  11. Mayurpatil155
    Froyo Aug 2, 2017
    are you sure that it is not going to affect the device
    G_jonny_cool_nxOr likes this.
  12. G_jonny_cool_nxOr
    Jelly Bean Aug 3, 2017
    G_jonny_cool_nxOr , Aug 3, 2017 :
    No brother i'm damn sure it wont .. I have done it and many if them have .. none is affected so you can go on
  13. rahul13nair
    Cupcake Aug 3, 2017
    rahul13nair , Aug 3, 2017 :
    how? has it released?
  14. Mayurpatil155
    Froyo Aug 3, 2017
    Mayurpatil155 , Aug 3, 2017 :
    Yes, the update is already available for 4.5.7 and if the update is not available in your country then the procedure to update the device has been provided above
  15. G_Bala_Gurunathan_uQKj
    Cupcake Aug 3, 2017
  16. Nandaraj04
    Cupcake Aug 5, 2017
    Nandaraj04 , Aug 5, 2017 :
    After update there is battery issue . at night even the phone is not working then too there is use of battery life of 10-15%
    Is there any solution to this??
  17. Mr. Vandelay
    Jelly Bean Aug 5, 2017
    Mr. Vandelay , Aug 5, 2017 :
    1. Turn the phone off.
    2. Hold Power and Volume Down
    3. English (or pick any language that you want)
    4. Wipe data & cache
    5. Wipe cache
    6. Yes
    7. Reboot
    The cache partition contains most of the temporary files, logs and remembered bits from the various applications on your Android device. They can also be left over files from before your last Android update. If that happens your device could be trying to use stored files that are not meant for your current version of Android. Think of it the same way you think of your browser cache. Just like a browser cache, sometimes those stored bits cause more problem than they solve and so it is a good idea to delete the cache periodically.
    Wiping the cache will NOT delete your apps or your data or your configuration. It will simply delete the temporary junk.
  18. ayushpoptani35
    Donut Aug 5, 2017
  19. arunnechlani
    Eclair Aug 5, 2017
  20. arunnechlani
    Eclair Aug 5, 2017
