Battery drain issue in Oxygen 4.5.8
  1. Raffi5555
    Ice Cream Sandwich Aug 7, 2017
    Raffi5555 , Aug 7, 2017 :
    Here you go:
    Turn off your OnePlus 5
    At the same time, hold the Home button, Power and Volume button
    Wait until the phone vibrates and the OnePlus logo shows up
    Release the Power button, but still hold the other buttons
    Now highlight the Wipe Cache Partition option and use the Power button to select the option
    Go down to Yes and use the Power button to select it
    Press the power button to select Reboot System Now
    The OnePlus 5 will now reboot and clear the system cache
  2. Raffi5555
    Here you go:
    Turn off the OnePlus 5
  3. shubhekshajalan
    Cupcake Aug 7, 2017
    shubhekshajalan , Aug 7, 2017 :
    I still have to charge my phone twice a day with moderate usage. I'm ending the day at around 20% or so. I get barely 4-5 hours SOT.
    On overnight standby, I am losing around 30% battery and the major culprits seems to be Android System and Android OS. I slept last night with 95% battery and woke up with 66% after 8 hours of sleep. This is beyond ridiculous. I have tried to wipe my cache multiple times, it doesn't help at all. Are there any other fixes? Otherwise I'm seriously considering returning this phone, the battery has been troubling me ever since I got it.
    F_Love_Patel_ZDpk likes this.
  4. adpro
    KitKat Aug 7, 2017
  5. gordonlaukongting
    Froyo Aug 7, 2017
    gordonlaukongting , Aug 7, 2017 :
    I have similar power problem last night.
    Usually I would charge from 10-20% back to 99-100% before sleep. Then the next morning will drop about 4-5% only and still seeing 93-94% battery. But this morning, my battery dropped from 99% to 58%, 41% drop during night while should have only minimal backgroup apps running.
    Anyway, if the Wipe cache will fix, I will do it.
    Just a bit correction to tian12345, you should just hold the power and the volume down buttons.
    No need to hold volume up button nor home button.
    Below is the link got from Dr. Google easily how to boot to recovery mode also if still having trouble to do so.
    https://www.androidexplained.com/oneplus-5-recovery-mode/
    Will see after wipe cache the coming 2 days will have battery draining problem over night.
  6. Mr. Vandelay
    Jelly Bean Aug 7, 2017
    Mr. Vandelay , Aug 7, 2017 :
    To fix issues after any update. wipe the cache partition.
    1. Turn the phone off.
    2. Hold Power and Volume Down
    3. English (or pick any language that you want)
    4. Wipe data & cache
    5. Wipe cache
    6. Yes
    7. Reboot
    If the issues persists then do a factory reset.
    Settings >> Backup & Reset >> Factory Data reset >> Reset phone.
    F_Jorden_Grewal_QmtA likes this.
  7. shubhekshajalan
    Cupcake Aug 7, 2017
    I mentioned in the post that I have already done this multiple time and it didn't work.
  8. shubhekshajalan
    Cupcake Aug 7, 2017
    No, I haven't done a factory reset.
    It's Android System & OS on standby which are draining my battery heavily.
  9. gordonlaukongting
    Froyo Aug 7, 2017
    I had the same problem last night. 99% dropped to 58% over night. Before the OS 4.5.8 update it was just 4-5% max dropping over night. Something is wrong after the 4.5.8 update.
    By the way, I just see in another thread saying Wipe cache in Recovery mode will help fixing this. You may try that.
    I just try, and will see how it performs till tomorrow.
  10. Mr. Vandelay
  11. BabjiKundateeri
    Cupcake Aug 7, 2017
  12. F_Jorden_Grewal_QmtA
    F_Jorden_Grewal_QmtA , Aug 7, 2017 :
    I had the same issue with battery and wiping my cache solved the problem.
    Mr. Vandelay likes this.
  13. dipesh mehta
    Froyo Aug 7, 2017
    dipesh mehta , Aug 7, 2017 :
    thank you so much
  14. pratikdoshit
    Gingerbread Aug 7, 2017
  15. TonioLA
  16. shubhekshajalan
    Cupcake Aug 8, 2017
    shubhekshajalan , Aug 8, 2017 :
    I did a factory reset as well. Issue still persists. Lost 15% in standby in just three hours. This is ridiculous.
  17. Big Cam
    Honeycomb Aug 8, 2017
    Big Cam , Aug 8, 2017 :
    +1 for unnecessary battery drain on 4.5 8
    I lose 10% in 6 hours overnight with no applications open.
  18. G_Marco_Maiano_Acpb
    Cupcake Aug 8, 2017
    G_Marco_Maiano_Acpb , Aug 8, 2017 :
    Me too i'm experiencing faster battery drain with 4.5.8, and already did cache clearing for apps and in recovery. Please fix it is very annoying and a bad user experience such a worse battery performance
  19. molsonalex
    Eclair Aug 8, 2017
    molsonalex , Aug 8, 2017 :
    Yah. It's pretty bad since 4.5.8. Did a clear cache a few days ago and didn't help. Getting less than 5 hours of SOT compared to 7+ hrs before the update. Didn't install any new app since then. Wifi used 8% of my battery and 6% it phone idle.
