Battery drain issue in Oxygen 4.5.8
  1. ritendebnath
    Eclair Aug 5, 2017
    #41
  2. Mr. Vandelay
    Jelly Bean Aug 5, 2017
    Mr. Vandelay , Aug 5, 2017 :
    I wiped the cache partition after installing the update and I have no issues (Battery, WiFi..etc).
    #42
  3. Punit Verma
    Cupcake Aug 5, 2017
    #43
  4. G_Shoukath_Ibnu_Busthan_
    Donut Aug 5, 2017
    G_Shoukath_Ibnu_Busthan_ , Aug 5, 2017 :
    hi am using one plus 5, wen I bought that time battery was working awesome even am getting a good backup but now a days battery draining so far. because of battery problem only I left Samsung mobikes. please help me for this
    #44
  5. indrajit4
    Honeycomb Aug 5, 2017
    #45
  6. nileshpatil5
    Donut Aug 5, 2017
    #46
  7. G_Swapnil_Chitnis_NAIz
    Eclair Aug 5, 2017
    G_Swapnil_Chitnis_NAIz , Aug 5, 2017 :
    I cleared the cache but from settings>storage and memory>cached data. Will that work? Or should I follow steps mentioned by you?
    #47
  8. AshutoshShandilya
    Eclair Aug 5, 2017
    #48
  9. Mr. Vandelay
    That won't work. You just cleared Apps cache.
    #49
  10. shethsa
    Cupcake Aug 5, 2017
    shethsa , Aug 5, 2017 :
    It seems to have worked for me. Thx!
    #50
  11. Nalir
    Donut Aug 5, 2017
    Nalir , Aug 5, 2017 :
    I was using my OP5 for two wks now and experience is remarkable. My battery life was more than 28hrs on my regular use for a full charge. But today I am noticing it gives 9hrs only. I restarted, did the catch wipe but still same. Pls advice what to do and why its changed all of a sudden like this. See below screenshot.
    #51
  12. _aditya17
    Cupcake Aug 5, 2017
    _aditya17 , Aug 5, 2017 :
    even after the 4.5.8 update the battery life did not improve. infact i kept a check on my standby slept for 7 hrs, wiped my cache, closed all wifi, 4g, location, recent apps yet when i got up and checked it dropped a 6% ! also since the 4.5.8 you do get EIS on 4k but can significantly notice the battery drains much faster (I'd suggest not to upgrade to the 5.8)
    #52
  13. Nalir
    Donut Aug 5, 2017
    Mine is 4.5.6 and status says upto date. Any idea.
    #53
  14. Benny Richard Dickson_
    Cupcake Aug 5, 2017
    Benny Richard Dickson_ , Aug 5, 2017 :
    Before this Oxygen 4.5.8 update, my battery life was good. Ever since I got this update my battery life has become so worse and I have never seen my phone's charge below 20% since I bought this phone.
    #54
    Nikita_Malhotra_21 likes this.
  15. Senti3nt
    Ice Cream Sandwich Aug 5, 2017
    Senti3nt , Aug 5, 2017 :
    Why do you make new thread? You should be posting in the main thread of 4.5.8 update.
    #55
    Mr. Vandelay likes this.
  16. F_Gurkirat_Singh_Mehrok_
    Gingerbread Aug 5, 2017
    #56
  17. Nepariri
    Nepariri , Aug 5, 2017 :
    Clearing cache never fixed shit in my case.
    I emailed bughunters and still waiting for a reply. 6% down in just ten minutes. Im getting angry and no ones telling me how to downgrade back to 4.5.6. Had ZERO issues with it, would get a day and a half of moderate usage. No bugs, no lag, no insane battery drain. I didn't buy this phone for the camera so I dont need the EIS in 4K, i need 4.5.6 back *******
    #57
  18. G_Krishna_Chaitanya_uNVw
    Cupcake Aug 5, 2017
    #58
  19. svvenn
    svvenn , Aug 5, 2017 :
    Give it a few cycles before you come here. I have amazing battery life with new update.
    and 100% to 96% doesn't say anything about battery drain, it is supposed to drain faster in the beginning. If you get like 6-7h SOT in the end, you are absolutely fine.
    #59
  20. G_Shreyas_Mohanty_NtCe
    Donut Aug 5, 2017
    G_Shreyas_Mohanty_NtCe , Aug 5, 2017 :
    Nobody owes you anything, so stop whining about how nobody's "telling you anything".
    If wiping cache didn't help, try the factory reset. This is an issue with your phone and your phone only, Oneplus or anybody else didn't mess up. Factory reset should fix whatever is creating the issue.
    If it doesn't, head over to XDA, there are many tutorials on how to flash an older ROM version.
    #60
