Battery drain issue in Oxygen 4.5.8
  1. Rock Rishabh
    Donut Aug 6, 2017
    Rock Rishabh , Aug 6, 2017 :
    yes I m also having same problem one plus need to solve this and also I m having song lag in the phone
    My phone hang sometimes
  2. g4ghouse
    Cupcake Aug 6, 2017
    g4ghouse , Aug 6, 2017 :
    Wipe your cache and check... if it doesn't work, reset the factory settings. This should help.
  3. dtruffo
    Donut Aug 6, 2017
  4. zskm10
    Donut Aug 6, 2017
    zskm10 , Aug 6, 2017 :
    for wiping cache do need root you can power on by pressing volume down + power button simultaneously then recovery mode wipe only cache no data required.
  5. bhansali1986
    Cupcake Aug 6, 2017
    bhansali1986 , Aug 6, 2017 :
    how to wipe the cache
  6. v_mag
    Donut Aug 6, 2017
    v_mag , Aug 6, 2017 :
    Shut phone off. Hold power button and volume down button for about 15 seconds. Enter your password. Select "Delete Data or Wipe Cache". Select Wipe Cache. Wait a bit and your done.
    sridhar_cool2900 likes this.
  7. Rahul Vashisht
    Froyo Aug 6, 2017
  8. sridhar_cool2900
    Cupcake Aug 6, 2017
    sridhar_cool2900 , Aug 6, 2017 :
    Guys switch off your mobile and while staring again just click power and volumedown button...clear catche and the battery drain problem will go....
  9. dtruffo
    Donut Aug 6, 2017
  10. Anand_Sagar18
    Jelly Bean Aug 6, 2017
    Anand_Sagar18 , Aug 6, 2017 :
    for me ... opposite happened. after updating the phone. seems to stable enough and the battery drainage reduced . over last night it only drained approx 2% even when data connection was active
    B1512267027836 likes this.
  11. velumani
    Froyo Aug 6, 2017
  12. vtambade
    Gingerbread Aug 6, 2017
  13. JaniMous
    JaniMous , Aug 6, 2017 :
    You are basing that on what? 10 mins of usage time? The calculated remaining time is based on your usage, not the battery's health/draining. If it loses more than 20% overnight, then you have the right to say that there's something wrong.
  14. JaniMous
    Guys, the battery takes a while to stabilise after a new update. Give it some time and stop worrying about it.
  15. SenthilSubbaiah
    Donut Aug 6, 2017
    SenthilSubbaiah , Aug 6, 2017 :
    which cache needs to be cleared ?
  16. G_Aravind_Prashanth_qKyO
    Froyo Aug 6, 2017
  17. Dilipksingh92
    Eclair Aug 6, 2017
    Dilipksingh92 , Aug 6, 2017 :
    same here .... facing battery drain issue after update
    how do I roll back to 4.5.7 it had great battery backup
  18. Deactivated User
    Aug 6, 2017
  19. Santoshkore1994
    Donut Aug 6, 2017
  20. Rahul11791
    Rahul11791 , Aug 6, 2017 :
    do clear cache in recovery or factory reset...bugs in prev version interferes with new system thats why these pblm arise.
