2
Battery drain issue : One Plus 7
  1. Tushar Wattal
    Cupcake Mar 22, 2021
    Tushar Wattal , Mar 22, 2021 :
    I have been having battery drain issue for the past 2 weeks after the update 10.3.8
    Whether it is on standby mode or normal working mode
    The power discharges so quickly I have to charge twice or thrice a day
    Can someone share light on this
    Regards
    ch_srinivasan and JuanjoMontoya like this.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Mar 22, 2021
    Dresa91 , Mar 22, 2021 :
    Hey
    Can you please share your usage and battery stats?
    Bobbie63 and JuanjoMontoya like this.
  3. Tushar Wattal
  4. Dresa91
    Can you please share the stats when you have around 25%?and then please also share the detailed usage (three dots in the upper right corner)
  5. Tushar Wattal
    Cupcake Mar 25, 2021
  6. Tushar Wattal
  7. Dresa91
    User of the Year 2016; Most Active User 2020 Mar 25, 2021
    Bobbie63 likes this.
  8. Bobbie63
    Marshmallow Mar 25, 2021
    Bobbie63 , Mar 25, 2021 :
    Not much we can say for the moment as you’ve just charged your phone, what you could do right now and see if it improves is to clear the cache and data of Google Play Services and see if that helps. (But first charge to 100%), after that check the stats again when it’s down to 20-25% like @Dresa91 said. Don’t change anything in the settings to try to reduce the drainage, just use it like you normally do.
    Dresa91 likes this.
  9. Tushar Wattal
    Cupcake Mar 26, 2021
  10. Dresa91
    User of the Year 2016; Most Active User 2020 Mar 26, 2021
  11. naveenkumar59
    Cupcake May 16, 2021
  12. Khushii21
    Ice Cream Sandwich May 17, 2021
