battery drain issue with Oneplus 5 . please help
  1. P1515935549965
    Cupcake Jul 22, 2018
  2. MJ_Vikram
    KitKat Jul 22, 2018
    MJ_Vikram , Jul 22, 2018 :
    some app is running in background, if android system is consuming more wipe cache in recovery.
  3. P1515935549965
    P1515935549965 , Jul 22, 2018 :
    I cleared my cache but still issue is not solved . my battery is draining without any actual load . like draining when phone is ideal when I am sleeping or not using .
  4. MentalDraco
    Marshmallow Jul 22, 2018
    MentalDraco , Jul 22, 2018 :
    It's awake so find what's causing it
  5. G_T_Bennett
    Jelly Bean Jul 22, 2018
  6. Anurag Anasane
    Froyo Jul 22, 2018
    Anurag Anasane , Jul 22, 2018 :
    Go to location and in options turn off wifi scanning and Bluetooth scanning. Turn off your phone for 30 seconds and then restart. Go to developer options, running services and see which app is running continously try to force stop it. Also if ur location is set to highs accuracy it may drain ur battery fast.
  7. abouaymane
  8. G_T_Bennett
    Jelly Bean Jul 23, 2018
