battery drain issue via OnePlus 6
  1. X1529599052466
    Cupcake Jan 23, 2020
    X1529599052466 , via OnePlus 6 , Jan 23, 2020 :
    I have battery drain issue after recent update...battery drain from 100 to 30% within 6 hours if I use GPS services
    its been 1year 6months I purchased this mobile..do I need to change 🔋 battery
  2. Abhishek654
    Gingerbread Jan 23, 2020
    Abhishek654 , Jan 23, 2020 :
    no need to change battery your battery life is fine just ignore the drain because it's not draining.
    yeah after using 1years 6months battery might be effected but its's totally normal.
    X1529599052466 likes this.
  3. Milanpatel7
    Cupcake Jan 24, 2020
  4. Caomhin
    KitKat Jan 24, 2020
    Caomhin , via OnePlus 6T , Jan 24, 2020 :
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    Battery Calibration/Heating Tips: How To Improve Battery Life !!
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    Kytharsis likes this.
