Battery/Charging battery drain issue
  1. gearam balaji
    Donut Feb 3, 2017
    cellx likes this.
  2. IchBinNichtSafe
    Cupcake Feb 3, 2017
  3. Bartnl
    Lollipop Feb 3, 2017
    Bartnl , Feb 3, 2017 :
    Have a look in the battery stats and see what is draining your phone.
    With the info given right now, no one can help you.
    Furthermore if you use the search with keyword battery you will find loads of threads with possible solutions.
    Kiran.a.joseph likes this.
  4. G_Harish_Babu_ZgkD
    Cupcake Feb 3, 2017
  5. Master_TC
    Jelly Bean Feb 3, 2017
    Master_TC , Feb 3, 2017 :
    How can we help you, if you give us only these information? How abaout battery stat? Apps you use?
  6. G_Platini_Ruzario_MxgQ
    Cupcake Feb 3, 2017
  7. Glenndalf
    Froyo Feb 3, 2017
    Glenndalf , Feb 3, 2017 :
    Hi people I had the same problem since I updated to Nougat. After reading and researching online, most people are saying there's a bug and recommend to turn off Back up in settings. I still had the problem though so I done a factory reset via turning the phone off and holding the volume down and power button and wiping the cache and phone. My phone has been much better since, I'm getting 6 to 7 hours on screen time instead of 4 to 4 and a half. I hope this helps and you get it sorted.
    G_Mr_.... likes this.
  8. elementneha
    Cupcake Feb 3, 2017
    elementneha , Feb 3, 2017 :
    talk to OnePlus support....you can find their toll free number on their website they will help u.
  9. G_julu_evauxcorbiat_UfBa
    Cupcake Feb 5, 2017
    G_julu_evauxcorbiat_UfBa , Feb 5, 2017 :
    I am facing the same. Battery stat presents a (very) high consumption due to Android system ~(14% after 3h) and also Multimedia (~13%) whereas I am in fly mode only connected to wifi. I did a factory reset which helped but still a lot of drain due to Android system (in the details 51 sub routines look working even if the wifi is switched off)
    Any idea how to reduce some of them?
  10. G_rich_jay_fhNW
    Gingerbread Feb 5, 2017
    G_rich_jay_fhNW , Feb 5, 2017 :
    awwwww
  11. airiartev
    Jelly Bean Feb 6, 2017
  12. hiteshsahu383
    Cupcake Feb 6, 2017
    hiteshsahu383 , Feb 6, 2017 :
    I to have same problem. every night my mobile had 65-70% battery but when I check morning it got reduce and only 6-7% battery left.
    please provide some solutions .
  13. anmolarora23
    Cupcake Feb 7, 2017
  14. G_Abhishek_Mittal_MvyG
    Cupcake Feb 7, 2017
  15. F_Elio_Tognacca_TmPw
    Cupcake Feb 7, 2017
    F_Elio_Tognacca_TmPw , Feb 7, 2017 :
    hie , it's thé print sensor witch is constantly working (bug) witch is draining thé batterie and make the device warm .
    i have solve that problem with à recovery of my device , "recovery at state of manufacture"
    this problem is solve
