12
Battery Drain Issue
  1. 48578 Donut Dec 3, 2018
    48578, Dec 3, 2018 :
    I noticed after the Oxygen OS 9.0.2 update, there's been battery drain in the OnePlus 6. Anyone else noticed this? If yes, OnePlus support team please fix this in the next update
  2. Shabarish_Menon Froyo Dec 3, 2018
  3. Z1530084800741 Cupcake Dec 3, 2018
  4. ashwinhr Cupcake Dec 3, 2018
    ashwinhr, Dec 3, 2018 :
    I'm having the same issue with my OnePlus 6. I just got mine last week and after updating to the OS 9.0.2, my battery went from 100 to 53 percent overnight while not being in use. I don't have any info on what caused that on the Battery setting.
  5. W1543851288776 Cupcake Dec 3, 2018
  6. Z1530084800741 Cupcake Dec 3, 2018
  7. D1527499581383 Cupcake Dec 3, 2018
  8. cosminsalasan Eclair Dec 3, 2018
  9. SolarEclipse KitKat Dec 3, 2018
    SolarEclipse, Dec 3, 2018 :
    Battery issues are user issues as most users are on the same hardware and base O/S / Launcher.
    So, find the app or apps causing your issues and do one or more of the following:
    • Uninstall the app
    • Work with the app's developers to fix app to work with Pie and Oxygen
    • Tweak the settings for the app. Likely set the sync settings to manual.
    • Live with the battery life
    Sanpat1 and Kytharsis like this.
  10. ashwinhr Cupcake Dec 3, 2018
    How do I know which app is causing the issue when there are no apps listed in the Battery Detailed Usage list?
    VineetKamble and AryanSathish like this.
  11. Shabarish_Menon Froyo Dec 3, 2018
    Shabarish_Menon, Dec 3, 2018 :
    what to tell the developers of insta, youtube,etc.
    my phone is showing notifications that insta is using too much battery ,same with youtube ,crome and camera is using 12% battery life.
    i have cleared cache of all these apps and am using deep clear recent app management from settings.
    dont know wats wrong.
    will updating my phone by downloading 9.0.2 ota and flasing it again help?
    VineetKamble and Ricanstyle like this.
  12. Shabarish_Menon Froyo Dec 3, 2018
    same is my case its showing crome,camera,youtube,play services,etc.
    Sanpat1 and Ricanstyle like this.
  13. cosminsalasan Eclair Dec 3, 2018
    cosminsalasan, Dec 3, 2018 :
    Not really!
    I know they by-the-book there should be an app doing it. Checked before posting several times and the is no such thing. Within those 30 minutes right after a full charge the is no info. When the info about the battery use becomes available there is no app listed. Only the system components. But 5% of battery is gone.
    I am not a new in smartphone use and had almost all OP models so far usually complemented by other Android and iOS phones. That is to say I have a slight idea where to look and what to check...
    VineetKamble and Sanpat1 like this.
  14. A1538556034274 Cupcake Dec 3, 2018
    Ricanstyle likes this.
  15. S1528718191678 Cupcake Dec 3, 2018
  16. Kytharsis Lollipop Dec 3, 2018
    Kytharsis, Dec 3, 2018 :
    It helps us a lot more if you actually share your screenshots...
  17. filipebatt Gingerbread Dec 3, 2018
  18. Miratek Honeycomb Dec 3, 2018
    Miratek, Dec 3, 2018 :
    So the Update 9.0.2 is indeed not battery friendly. This is not an user specific issue because so many people reported the problem with that version. Please OnePlus, fix this.
    Screen on time went from 6-7 hours to about 3-5 with this update!
  19. batmanlego3 Cupcake Dec 4, 2018
    batmanlego3, Dec 4, 2018 :
    dam mine last perfectly fine I dually charge my phone to 80% and I am good for my day
  20. vishwa_nath97 Cupcake Dec 4, 2018
    vishwa_nath97, Dec 4, 2018 :
    I too have the same problem but no one has a solution to it. Clearing cache memory or having a black wallpaper doesn't help.
