Battery drain issue
  1. Shiva raju122
    Donut Dec 27, 2018
    D1529506113844 likes this.
  2. AmanRaj7
    Donut Dec 27, 2018
    AmanRaj7 , Dec 27, 2018 :
    when did you buy it? If its new, then give it some time to adapt. It will improve .
  3. Shiva raju122
    Donut Dec 27, 2018
    Shiva raju122 , Dec 27, 2018 :
    I have purchased on 13 Dec
  4. AmanRaj7
    Donut Dec 27, 2018
    how much of screen on time are you getting?
  5. Shiva raju122
    Donut Dec 27, 2018
  6. Catalin_Buzescu
    Jelly Bean Dec 27, 2018
    Catalin_Buzescu , Dec 27, 2018 :
    And you think 6hrs means battery drainage? What do you compare your stats to?
    Some screenshots of both battery graphs would help.
  7. Shiva raju122
    Donut Dec 27, 2018
  8. Catalin_Buzescu
    Please provide more details, as in OOS version, stock or custom rom, etc
    It seems Google play services is causing a bit of a havoc. I usually enter storage option in this app's settings and and clear all data. Usually it settles after.
    If you click the 3 dots in that screenshot it would show full system usage. Do that and post
  9. AmanRaj7
    Donut Dec 27, 2018
  10. Shiva raju122
    Donut Dec 27, 2018
  11. Shiva raju122
    Donut Dec 27, 2018
  12. Catalin_Buzescu
    Not that. Next to the magnifier glass, you have 3 dots. Click that and click full device usage.
    Now, post that.
    Also in my opinion 6hrs is good. Make sure to measure from 100%-5%. To make the best judgement
  13. Shiva raju122
    Donut Dec 27, 2018
  14. Catalin_Buzescu
    So, as a conclusion:
    * you charged the phone almost 2 days ago
    * it still has 8 more hrs to go. Let's round up the usage at around 48hrs
    * Screen is taking the most of usage, which is the best case scenario
    * Google play services can be amended (switch off gps when not using, switch off wifi scanning, etc), clear all data from Google play services
    It's some great stats in my humble opinion.
    What were you expecting though?
  15. Shiva raju122
    Donut Dec 27, 2018
    Thanks for ur help...
  16. Catalin_Buzescu
    I ended my comment with a question. I was hoping on an answer from you. That is unless you're too busy
    Btw, the suspension dots on the end of your quote don't make sense
  17. AmanRaj7
    Donut Dec 27, 2018
    10-90 is quite fast 65 mins around or less, after that it takes 15-20 mins to get to 100
  18. red_cruz25
    Eclair Dec 27, 2018
    red_cruz25 , Dec 27, 2018 :
    hello my phone just arrived yesterday and is it to fully charge my phone everytime i charged it? or is it ok to charge from 20-90%?
  19. AmanRaj7
    Donut Dec 27, 2018
    i always go for 20-90 cycle pattern.
  20. red_cruz25
    Eclair Dec 27, 2018
    and charge it to 100% once a week sir is it ok?
