OxygenOS battery drain issues
  1. raajpradheep
    Gingerbread Feb 19, 2017
    raajpradheep , Feb 19, 2017 :
    hi,
    I face battery drain issue after updating to nougat. I all the update which was released and still facing the battery drain issue. I did clear the cache and still it doesn't help. help pls
  2. airiartev
    Jelly Bean Feb 19, 2017
  3. Dropjawaudio
    Donut Feb 19, 2017
    brelak likes this.
  4. sherigarvikram
    Cupcake Feb 19, 2017
    sherigarvikram , Feb 19, 2017 :
    Probably one of the installed Apps could be consuming more power. Pls check Settings > Device > Battery. Hope this helps!
  5. F_Uday_Bhanu_Pradhan_bQE
    Donut Feb 19, 2017
    F_Uday_Bhanu_Pradhan_bQE , Feb 19, 2017 :
    boss searching threads wont help.. all u get the solutions like.
    1. restore factory setting.
    2. wipe cache n data.
    3. turning off wifi.. net.. Bluetooth.. almost everything smart abt a smart phone..
    4. bunch of silly procedures.. in the end u have to start from zero again.
    hope next ota will have more solutions than issues...
  6. G_Bharathi_Kannan_Kumara
    G_Bharathi_Kannan_Kumara , Feb 19, 2017 :
    Use ShutApp or clean master to find which app eats the battery.
    I use security app that analyze battery usage of the application before I install.
  7. suhasgpawar
    suhasgpawar , Feb 19, 2017 :
    That's correct, probably some application is running in the background and causing battery to drain.
    Try resetting phone,it may help.
    Don't forget to backup.
    Good Luck.
  8. cmitchellshaw
    KitKat Feb 20, 2017
    cmitchellshaw , Feb 20, 2017 :
    actually, upgrading from 3.2.8 (Android 6.0) to 4.0.x (Android 7.0) leaves to many traces of the old system in place, which causes a litany of problems, including bad battery performance.
    the best solution is to do a backup and full wipe as part of the upgrade. here is the proof: I did a full wipe coming from 3.2.8 and wiped the cache for each upgrade after that. I've never had a single problem. here's my battery (screenshot taken last night)
  9. beiyuan
    Donut Feb 20, 2017
  10. G_Avee_B_Xaxb
    Jelly Bean Feb 20, 2017
    G_Avee_B_Xaxb , Feb 20, 2017 :
    after nougat i got pretty much the same SOT but my standby time becomes a bit shorter and barely lasted a day.
  11. F_Uday_Bhanu_Pradhan_bQE
    Donut Feb 21, 2017
    F_Uday_Bhanu_Pradhan_bQE , Feb 21, 2017 :
    Ok. I accept that, but never felt such kind of issue with Xiaomi or Samsung or Moto devices. dont have to hard reset / format the phone after OTA.
  12. Zepoholic
    Cupcake Feb 21, 2017
  13. tekyan
    tekyan , Feb 21, 2017 :
    try going into Settings>Battery>Settings>Aggressive doze and app hibernation. Check on 'Enable aggressive doze and app hibernation'. try this and see if it works.
  14. cmitchellshaw
    KitKat Feb 21, 2017
    cmitchellshaw , Feb 21, 2017 :
    did you update those devices from Android 6.0 to 7.0? if not, it's not a fair comparison.
  15. jim262
    Ice Cream Sandwich Feb 21, 2017
  16. G_faizreylord_P_A_E_H_FI
    Donut Feb 21, 2017
  17. G_faizreylord_P_A_E_H_FI
    Donut Feb 21, 2017
