battery drain issues
  1. Tharun_Thamatam
    Cupcake Jul 27, 2018
  2. Deactivated User
    Jul 27, 2018
  3. Tharun_Thamatam
  4. Waveform Modifier
    Marshmallow Jul 27, 2018
    Waveform Modifier , Jul 27, 2018 :
    Welcome to the community. There is no OnePlus Staff here in these parts and only community users is here and only community users is here. As these forums has rules, please find the links below and try your best to follow it (eg. use search).
    https://www.themobileindian.com/how-to/how-to-fix-android-os-and-android-system-battery-drain-18698
    Forum rules below for your reference.
    https://forums.oneplus.com/threads/oneplus-forum-guide-for-cupcakes.804637
    https://forums.oneplus.com/threads/checklist-before-posting-a-new-thread.104690
  5. sidyeti
    Froyo Jul 27, 2018
    sidyeti , Jul 27, 2018 :
    after trying cache wipe from recovery mode ( that doesn't remove data), try slow charging the phone once (without using dash charger). this helped a lot.
  6. Tharun_Thamatam
    Cupcake Jul 30, 2018
    Tharun_Thamatam , Jul 30, 2018 :
    Hello, thanks for the reply. I already searched for similar issues, didn't find a fix or leads. Hence created a new thread. Any leads regarding solving the issue would be appreciated.
  7. Tharun_Thamatam
    thanks for the suggestion. I don't have another USB c cable other than the OP Dash cable. I will try to wipe cache. [e]1f44d[/e]
  8. sidyeti
    Froyo Jul 30, 2018
    sidyeti , Jul 30, 2018 :
    use the same cable and charge it via pc/laptop USB port. it will charge slowly
    Tharun_Thamatam likes this.
  9. TRANILKUMAR
    Cupcake Nov 28, 2019
    TRANILKUMAR , Nov 28, 2019 :
    OnePlus 6 battery draining fast.
    after full charge 5hrs of usage only.
    even I didn't get system update still running on Android 9 pie and OnePlus OS version 9. waiting for the updates.
  10. Waveform Modifier
    Marshmallow Nov 28, 2019
    Waveform Modifier , Nov 28, 2019 :
    Wrong forum
