2
Battery drain on oneplus 8 via OnePlus 8
  1. D_N
    Cupcake Jun 10, 2021
    D_N , via OnePlus 8 , Jun 10, 2021 :
    In my recent days, my oneplus 8 SoT have been reducing.
    At early stage of my phone my SoT used to be 8hrs but now it is less than 6 hrs (using 60hz refresh rate) for daily usage.I don't know the reason whether it is due to update. Oneplus please look up to this.
    glydex and Ranjit2206 like this.
  2. Ranjit2206
    Honeycomb Jun 11, 2021
  3. Ranjit2206
  4. Sree_nu
    Cupcake Jun 11, 2021
  5. Hari196
    Donut Jun 11, 2021
  6. G1622390932365
  7. G1622390932365
  8. Cicala
    Honeycomb Jun 23, 2021
    Cicala , via OnePlus 8 T-Mobile , Jun 23, 2021 :
    🥇Contact One plus support if haven't done so. This was a discussion from another forum as well.
    Reviewing that particular forum. It appeared that, the devices that were facing those issues. Were not plugged into a sufficient wall Jack. Or were using a changer not compatible with the One plus Device's.
    Hope to have helped🕯️🤗😇
  9. YSRReddy
  10. Cicala
  11. O1599531902234
    Cupcake Jul 26, 2021
    O1599531902234 , via OnePlus 8 , Jul 26, 2021 :
    I'm also facing the same issue. My OnePlus 8 is draining out very faster these. I have a small cut in my charging cable. Can this be a reason by any chance? If not what shall be done?
  12. vsurajr
    Froyo Aug 5, 2021
    vsurajr , via OnePlus 8 , Aug 5, 2021 :
    I'm also facing the same issue after upgrade to official build 11.0.77.IN21.DA
    Is there any hot fix for this issue because the battery drains quickly even the phone is not using
  13. Y1594549631539
    Cupcake Aug 5, 2021
  14. AC130PL
    Cupcake Aug 6, 2021
    AC130PL , via OnePlus 8 , Aug 6, 2021 :
    90Hz, root, disabled location and permissions for GMS, Google etc.
    Score achieved with optimalized charging- it means that battery charges to 3600mAh, not 4300
  15. amanbanjara
    Eclair Aug 6, 2021
    amanbanjara , via OnePlus 8 , Aug 6, 2021 :
    They reduce the battery life after every update. Initially when we bought the OnePlus 8 it comes with android 10 and after 6 month android 11 comes with OnePlus 8t and 9 searies so they intentionally reduce the battery life. So they previous op8 users but new phone.
  16. sahil.amanu
    Gingerbread Aug 7, 2021
  17. Mustakim512634
    Eclair Aug 7, 2021
  18. Mustakim512634
    Eclair Aug 8, 2021
  19. P1623524003424
    Cupcake Aug 10, 2021
