[Submitted] Battery drain on op 8 pro
  1. Saketmn
    Cupcake Jul 3, 2020
    Saketmn , Jul 3, 2020 :
    My week old op 8 pro is getting barely 4 to 4.5 hrs of SOT with minimal usage, no games, settings is kept at FHD+ 120HZ. With people encountering so many issues with this phone thinking of replacing/refund as I still have some time. Any suggestions
  2. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Jul 3, 2020
    Suhas Klkrn555 , Jul 3, 2020 :
    Thanks for the logs. I’ve passed on the information to the relevant team and will get back to you in case of any further updates.
    Thanks & Regards,
    Suhas.
  3. Shanker1969
    Donut Jul 7, 2020
    Shanker1969 , via OnePlus 8 Pro , Jul 7, 2020 :
    I have the same story i use approx 8% with just scrolling of Instagram. And at night its ridiculous i left my phone at 11% at 12:30 am and it died when I woke up at 7am
  4. Z1594625632058
    Cupcake Jul 25, 2020
  5. Shanker1969
    Donut Jul 27, 2020
    Shanker1969 , via OnePlus 8 Pro , Jul 27, 2020 :
    Hey man . You should wait for updates. After two os updates my battery issues have been completely addressed. In fact the display issue has been fixed too(punch hole bending) . I think you should wait for a bit
    Z1594625632058 likes this.
  6. Z1594625632058
    Cupcake Jul 27, 2020
    Z1594625632058 , via OnePlus 8 Pro , Jul 27, 2020 :
    Thanks for the advice, how much time would it take for the updates to come into play...any idea?
    I like the phone as such, but the batter drain is a real issue.
  7. Shanker1969
    Donut Jul 27, 2020
    Well I'm not aware but the 10.5.12 update did the trick for me. I still loose battery but it's down to 3-4% overnight. I think you should study your battery usage maybe it's an app causing the problems. I'd suggest a factory reset too. And keep everything updated even the apps from play store. If you're enrolled in a beta group for an app get out of it. Helps sometimes.
  8. Z1594625632058
    thanks allot shanker, I depleted my battery to 0 and let it shut down, then recharged it to full. This lead to reduction in consumption.
    current OS is 10.5.12
    all my apps are updated, and no beta test apps.
    I shall as you suggested I'll wait and see for a few days.
  9. Shanker1969
    Donut Jul 27, 2020
    I'm glad man. Do reach out if there's a new issue. We can compare notes.
  10. ShivaSadhashivan
    Cupcake Nov 24, 2020
    ShivaSadhashivan , Nov 24, 2020 :
    Hi Team, I just bought an 8 Pro couple of days back over the weekend. I have not upgraded yet to Oxygen OS11 but I am still facing battery drain issues / average SOT. Perhaps it is not so bad as others but I get an SOT of hardly 4 hours without even any gaming. I haven't played a single game over the last couple of days. On the Display front, am on QHD+ and 120Hz all the time. As this seems to be a well known issue, am not posting any pictures but please let me know for any suggestions here. Am a bit sceptical about updating to OS11 as I think this could worsen the battery drain. I have been through 2 full charging cycles so far.
  11. bishaldev
    Cupcake May 20, 2021
  12. Shanker1969
    Donut May 21, 2021
  13. bishaldev
    Cupcake May 24, 2021
  14. Shanker1969
    Donut May 24, 2021
    Shanker1969 , via OnePlus 8 Pro , May 24, 2021 :
    4 hours sot is pretty standard on an 8 pro.
    I use 120hz and fhd+ and I at Max get 4 hours and 30 mins.
    Update to oos11 it's actually better in battery performance. The 11.5 one is genuinely great at battery backup
  15. Shanker1969
    Donut May 24, 2021
  16. bishaldev
    Cupcake May 25, 2021
    bishaldev , via OnePlus 8 Pro , May 25, 2021 :
    The major issue is that the battery drains very quickly than expected.
    I loose ~10-20% battery when I'm asleep.
  17. Shanker1969
    Donut May 25, 2021
    Shanker1969 , via OnePlus 8 Pro , May 25, 2021 :
    To counter that use these options.
    Works wonderfully.
    And in case you don't want to use this.
    A reset keeping your internal data intact should do the trick.
    Keep in mind that kind of reset only allows internal data to be backed. All your applications will get deleted.
    Also try deleting your cache once
