4
Battery Drain OP6 5.1.8
  1. N1528956008022
    Donut Jun 19, 2018
    N1528956008022 , Jun 19, 2018 :
    Hi All,
    I've updated the latest OS (5.1 8) and I'm still facing issues with Battery Backup. The phone usage is very minimal and the screen on time is very little. I'm not sure what to do???
    Please help!
  2. ZiiVic94
    Gingerbread Jun 19, 2018
    ZiiVic94 , Jun 19, 2018 :
    Many people are reporting the same condition as you (me too). I even received a message by a staff member, so I think OP is already working on it. For now try to wipe cache via recovery mode.
    iFrostizz likes this.
  3. N1528956008022
    Donut Jun 19, 2018
    done that, however no respite.. I'm charging my phone twice/thrice in a day... [e]1f61e[/e]
  4. ZiiVic94
    Then you have 2 choices: contact support (it's quite sure they'll make you downgrade) or install some app to manage battery discharge (I heard greenify is quite good) to gain time 'till an update is out.
  5. anshulmittal6
    Froyo Jun 19, 2018
    anshulmittal6 , Jun 19, 2018 :
    batter issue is very important to address.
    because all other challenges can be given less priotity at the moment.
    If such a great phone i need to charge very requently then what is the use of updating to new version.
    i would love yo be at 5.1.5 until Battery issue is fix.
    Oneplus6 plz take it on priority
    iFrostizz and ZiiVic94 like this.
  6. ZiiVic94
    I agree.
    anshulmittal6 likes this.
  7. Bmwgser
    Cupcake Jun 22, 2018
    Bmwgser , Jun 22, 2018 :
    Agreed, brand new phone.. updated at first switch on .. full charge and have lost 10% battery just listening to radio stream for an hour. seems excessive, poor..
  8. anshulmittal6
    Froyo Jun 22, 2018
  9. ZiiVic94
    Gingerbread Jun 22, 2018
  10. chlorobill
    Froyo Jun 29, 2018
    chlorobill , Jun 29, 2018 :
    What's for sure is that this doesn't happen to all of us. I saw no change in battery consumption. See attached screenshot, I pulled my phone off the charger almost 6 hours ago and I have used it quite a lot since. Still 17 hours remaining. I am on 5.1.8 OP6. It most probably is some app you are using.
  11. David0Ic
    Cupcake Jun 29, 2018
    David0Ic , Jun 29, 2018 :
    same problem. I replaced my Samsung s7 edge with OnePlus 6 but I had to go back. The battery drains to fast. Especially my display.
  12. N1528956008022
    Donut Jun 29, 2018
    N1528956008022 , Jun 29, 2018 :
    Guys! I was facing the same issue, went to service centre got my phone examined and they found some issue which resulted in a replacement.
    My phone was kept under observation for 2 days, a technician was collecting logs on periodic basis and troubleshooting the issue...
    I'm very happy with the new unit!!! No BATTERY DRAIN ISSUES!
    Please visit your nearest service centre and get your phone examined.
  13. xbonnaire
    Eclair Jun 30, 2018
    xbonnaire , Jun 30, 2018 :
    Can you tell me what are your op6 models? I have a A6003 and no problem with the battery under os 5.1.8.
  14. iFrostizz
    Froyo Aug 26, 2018
    iFrostizz , Aug 26, 2018 :
    you seem to have a hardware issue
