battery drain over 18% on OnePlus 7 without usage in night
  1. g swathi
    Cupcake Dec 8, 2020
    g swathi , Dec 8, 2020 :
    my battery keeps draining to over 15% over the night without usage of phone. wifi and location is on. please let me know what's wrong and what can be done
  2. C1589036270458
    Cupcake Dec 8, 2020
  3. g swathi
    Cupcake Dec 8, 2020
  4. g swathi
    Cupcake Dec 8, 2020
    not using any third party apps.. which apps do you mean
    this is the drain issue
  5. C1589036270458
    Cupcake Dec 8, 2020
    C1589036270458 , via OnePlus 7 Pro , Dec 8, 2020 :
    Have you installed any apps recently for customization or wallpaper? Try setting battery saver on tonight than compare your battery drain if it does the same then take backup and format your phone once if problem still persist then you might have either software problem after recent update and the last thing is battery might be damaged check with the service centre of oneplus
  6. Arjun_Choudhry
    KitKat Dec 8, 2020
    Arjun_Choudhry , Dec 8, 2020 :
    Do you have automatic backup on for WhatsApp?
  7. g swathi
    Cupcake Dec 8, 2020
    I don't backup my WhatsApp ever
  8. g swathi
    Cupcake Dec 8, 2020
    alright wil do the same and check. will update if any change is observed. thanks for the info
    C1589036270458 likes this.
