Battery drain overnight via OnePlus 8
  1. G_Aniruddh_Deshpande_mwj
    Donut Sep 16, 2020 at 10:19 AM
    tanweerezaz1991 likes this.
  2. junayed94
    Cupcake Sep 16, 2020 at 10:54 AM
  3. febellionvhhhbhj
    Cupcake Sep 16, 2020 at 10:58 AM
  4. Rajendra.Bhat
    Froyo Sep 16, 2020 at 11:02 AM
  5. Cheezburgers
    Gingerbread Sep 16, 2020 at 4:27 PM
    Cheezburgers , Sep 16, 2020 at 4:27 PM :
    had same issue before, found out its because of certain apps i had. Social media apps are usually the culprit. My advice is force stop all of the social apps/battery draining apps you have before sleeping, and check if you're still have drain issues.
    Another issue might be due to bad service in your area, so you can try airplane mode and see if it helps
