11
OxygenOS Battery drain Oxygen OS 3.0
  1. Pcline9
    Gingerbread Apr 1, 2016
    Pcline9 , Apr 1, 2016 :
    Me too, issue is with oxygen in battery settings, draining massively.
    My phone seems fine while I'm using it, but when it's idle in my pocket it gets warm and drains v fast. Like an anti-dose haha
  2. sungfive
    Ice Cream Sandwich Apr 1, 2016
  3. Rauttis
    Rauttis , Apr 1, 2016 :
    This has happened to me three times now, and yeah, my phone was always in my pocket. Makes me think it's the screen gestures going haywire in your pocket, I've disabled them for now and will see if it happens again.
    snerk one and Pcline9 like this.
  4. Dalveer
    Dalveer , Apr 1, 2016 :
    I did a dirty flash with 100% battery and wiped the cache before and after the update,but I'm having battery drain issues as.well. I have tried a charge cycle with no luck. I'm going to try greenify but since my phone is stock I heard it's not very effective
  5. Sandeep Poddar
  6. Vasilachi Eugeniu
    Honeycomb Apr 1, 2016
    Vasilachi Eugeniu , Apr 1, 2016 :
    factory reset helped me
    Pcline9 likes this.
  7. willy156
    willy156 , Apr 1, 2016 :
    Is clean install having to wipe data + cache before flashing 3.0 zip?
  8. Sandeep Poddar
    Sandeep Poddar , Apr 1, 2016 :
    Before this update already have formatted my phone 4 times :(
    Again a factory reset :(
  9. kryddan
    kryddan , Apr 1, 2016 :
    Could be the reason. I did a clean flash.
  10. BitterHoney
    Adityaf likes this.
  11. kryddan
    I flashed 2.2.1 stock which included wipe of everything, then copied 3.0 over to the phone and flashed it from stock recovery. After that I booted into temp-twrp-recovery and flashed twrp and supersu.
  12. vijaywidluv
    vijaywidluv , Apr 1, 2016 :
    I am on CM13 and am getting over 6hrs of SOT everytime
    abhishek7 likes this.
  13. dcyel
    dcyel , Apr 1, 2016 :
    I dirty flashed the rom, cleared cache two times afterwards, and the phone looses about 4-5% over night(10 hours) with WiFi and LTE on.
    So I am not in the same boat.
    Adityaf and snerk one like this.
  14. charanchakravarthi
    charanchakravarthi , Apr 1, 2016 :
    Checkout my batter drain...!! It's super crappy.. The good news is I see a guy in the graph..
    P.S. Tilt the right side of your phone to reveal him.. :p LOL..!!
  15. Vasilachi Eugeniu
    after factory reset i have no more battery drain by "oxygen"
  16. Ocole
    Ocole , Apr 1, 2016 :
    So I cleared cache and have re-installed the OS. I now have the oxygen drain of 20% (this wasn't there before - I use Nova launcher and thought this oxygen drainage problem was only with oxygen launcher)
    Will keep you posted if this works!
  17. Ocole
    What were you doing with your screen?! Haha
  18. MrMarvinKlein
    #38
  19. whyorean
    whyorean , Apr 1, 2016 :
    For those who not getting battery backup, try to calibrate your battery, first discharge it to 0, then charge back to 100, if possible then do this while your phone is switched off.
    Do mind wiping dalvic n cache too, if drain still persists.
    I feel such drains after every OTA update or ROM switch, so may be this helps you out too..
    GoodLuck, have a nice time ahead
    #39
  20. Pcline9
    Thank you for advice. Can I ask, how do you wipe dalvik? I've wiped cache from recovery but don't know where to find dalvik
    #40
