3
Battery Drain Test: OP7 Pro Battles It Out With Some Of The Best
  1. malidan
    Marshmallow May 15, 2019
    malidan , May 15, 2019 :
    Mr Who's battery drain test
    OP7 Pro 4000 mah
    S10+ 4100 Mah
    Honor P30 pro. 4200 Mah
    iPhone XS Max 3174 mah
    MI9 3300 Mah
    All device are set to max resolution,.
    But I found it strange he kept saying the OP was running in QHD, when we already know it knocks down to 1080p automatically on 1080P activities.
    Which is virtually the whole of this test.
    Njoy:D Or Not:rolleyes:
    Loveit, buntycubal and ilovesoneplus like this.
  2. Loveit
    Jelly Bean May 15, 2019
    Loveit , May 15, 2019 :
    That would (nearly) give me confidence in the MI9 as a daily driver - surprising.
    When I saw the 3300mah battery on release I instantly dismissed it but it holds out well. Still, not enough for me. Good phone recommendation to someone though..
  3. malidan
    The MI8 does almost 4 hrs of Pubg and still gets almost 8 hrs of Sot. On 100 mah more.
    £318 for the 64 Gb Mi9 if I cant get the 128 from a similar source I will grab it.
    That's now less than half the price of the OP7 Pro, how times have changed.;)
  4. Loveit
    Jelly Bean May 16, 2019
    Loveit , May 16, 2019 :
    Still not enough for me. After using the MiMax 2 as daily driver for a year even the P20 Pro seems like a compromise.
    malidan likes this.
  5. malidan
    Marshmallow May 16, 2019
    malidan , May 16, 2019 :
    Yes I see what you mean, you had some big daddies.:D
    Well if you unlock the bootloader, install a kernel and run Vanced in the background, the SOT will tell you it's to be as good.:confused:
    Loveit likes this.
