2
Battery drain using Samsung Accessories via OnePlus 7T Pro McLaren Edition
  1. robbertd97 , via OnePlus 7T Pro McLaren Edition , Dec 24, 2019 :
    Hello guys,
    I have been experiencing severe battery drain issues while using Samsung "Wearables". I see this is in issue with MANY OnePlus users on the Samsung Accessory Service app/plug-in in the Play Store.
    Has someone succeeded to deal with this problem?
    This has been going on since the start of November and seems to have to do with OnePlus and their Android 10 update.
    At the moment my Samsung Gear S3 and Galaxy Buds are unusable since they drain my phone by almost 30% per day.
    Hopefully someone has answers.
    harsh1682 and crack.design like this.
  2. #2
  3. #3
    robbertd97 likes this.
  4. raghava2030
    Donut Dec 26, 2019
    raghava2030 , via OnePlus 6T , Dec 26, 2019 :
    you acn use expanded screenshot feature while taking a screenshot. whenever you take a screenshot it will prompt for expanded screenshot.
    kilobravo99 and robbertd97 like this.
  5. raghava2030
    Donut Dec 26, 2019
    i am also experiencing alot of battery drain lately due the Samsung service due to which my phone is being charged multiple times daily.
  6. X1578578949175
    Cupcake Jan 9, 2020
    X1578578949175 , Jan 9, 2020 :
    OnePlus 6T owner here. Have been experiencing the same issue and would love to know what's suggested either work around or a solution?
    harsh1682 likes this.
  7. lolomjj
    Froyo Jan 10, 2020
    lolomjj , Jan 10, 2020 :
    OK I had the same problem on my 6T and I believe I've found a solution.
    You'll need to deactivate the battery optimization on all the Galaxy Wear apps & plugins as it force closes them and makes them reboot all the time, creating the battery draining.
    I've tried that for a couple of days now and it seems to have eradicated the phenomenon.
    Let me now if it worked for you too!
    robbertd97 and abhiyeli like this.
  8. raghava2030
    Donut Jan 11, 2020
    raghava2030 , via OnePlus 6T , Jan 11, 2020 :
    But if we opt for don't optimise it clearly tells it will affect the battery performance. i doubt this will fix the issue but will try and update.
  9. abhiyeli
    Cupcake Jan 20, 2020
    abhiyeli , Jan 20, 2020 :
    looks like its working for me too.
  10. raghava2030
    Donut Jan 24, 2020
  11. harsh1682
    Froyo Jan 24, 2020
    harsh1682 , via OnePlus 7T , Jan 24, 2020 :
    absolutely correct..! I also experienced this battery drain on OnePlus 7 and 7T for my Gear S3.. also sent a feedback to Samsung apps but no improvements till now. Hope OnePlus looks into this matter asap..!
  12. robbertd97 , via OnePlus 7T Pro McLaren Edition , Jan 26, 2020 :
    First and foremost, thanks everyone for responding. I did the same thing as you did and it worked for me. Thank you very much for the advice!
