Battery Drain/wakelock Systemupdateservice
  1. SantesMataro
    Donut Jul 21, 2014
    SantesMataro , Jul 21, 2014 :
    this is one of the issues that I care most.... because I don't want and can't be also looking por a wall to plug in my phone.. hope that when I get it there's somekind of update for this issue
    #41
  2. b.duterme
    Ice Cream Sandwich Jul 21, 2014
    b.duterme , Jul 21, 2014 :
    how did you remove google play services?
    #42
  3. coolguy949
    Froyo Jul 21, 2014
    coolguy949 , Jul 21, 2014 :
    Go to Settings > Apps > ALL > find "Google Play services" and uninstall updates. Wait a few minutes for Google apps to complain. Then open one of the Google apps like Hangouts and it will ask you to update Google Play services. Update it. That's what fixed it for me. Four days and no wakelock even after multiple reboots.
    #43
  4. napes22
    Honeycomb Jul 21, 2014
    napes22 , Jul 21, 2014 :
    Mine is greyed out. I'm not sure why.
    #44
  5. coolguy949
    Froyo Jul 21, 2014
    #45
  6. svhy
    Gingerbread Jul 22, 2014
    svhy , Jul 22, 2014 :
    You may need to tap Disable and then it should allow you to uninstall the updates.
    #46
  7. napes22
    Honeycomb Jul 22, 2014
    napes22 , Jul 22, 2014 :
    Thanks man, that worked!
    #47
  8. svhy
    Did it fix your main issue?
    #48
  9. riffraff81
    KitKat Jul 22, 2014
    riffraff81 , Jul 22, 2014 :
    don't have this problem at all.
    i'm rooted but everything is stock except for the audio and video player apps.
    #49
  10. napes22
    It did not. I'm still losing a good amount of battery daily from Google play services. Half as much as the screen, which is absurd.
    #50
  11. Archonix
    Cupcake Jul 22, 2014
    #51
  12. napes22
    Just tried the link. I only pay for 1GB of data per month, and that had already used 15MB, so hopefully these services will stop draining my battery and data.
    #52
  13. Archonix
    Cupcake Jul 23, 2014
    Archonix , Jul 23, 2014 :
    Ah, hope it works out for you. I've noticed it resolved my problems.. not sure about the data part though since I'm usually on WiFi...
    #53
  14. napes22
    Honeycomb Jul 24, 2014
    napes22 , Jul 24, 2014 :
    Me too, although now Android system is very high up in the usage list. But I'm assuming it was always that high, and I only noticed the Google Services at first.
    #54
  15. duffydack
    Gingerbread Jul 27, 2014
    duffydack , Jul 27, 2014 :
    Same issue for me. Plasy services update causes to keep awake constantly. I reverted the update and it fixed it. Applied the update again and same old same old, keep awake. I've since put mahdi rom and it's not just android system periodical wake ups. I'm used to seeing an empty Awake battery stat as I had a Nexus4. Drained 0-1% overnight. I might try the CM11S again, if I can find a factory image to flash.
    #55
  16. janek
    Eclair Jul 28, 2014
    #56
  17. duffydack
    Gingerbread Jul 28, 2014
    #57
  18. svhy
    Gingerbread Jul 29, 2014
    svhy , Jul 29, 2014 :
    I got tired of Google Services keeping my phone awake. I decided to give the fix a try.
    First, I had to deactivate Android Device Manager.
    Second, went into into Google Play Services and clicked on Disable.
    It then asked if I want to revert back to the factory version. I said Yes.
    Then, a notification popped up asking to update Google Play Services. I did.
    So far it seems to work. My phone has been on for over 11 hours and Google Play Services only kept it awake for 41 minutes.
    I haven't tried a reboot yet. I don't know if it'll revert to the same problem. If it does, I'll just do the fix again until there's an OTA to fix this problem.
    #58
  19. EddyOS
    Froyo Jul 31, 2014
    #59
    duffydack likes this.
  20. duffydack
    Gingerbread Aug 1, 2014
    #60
