2
Battery drain with CM12 Android-System-Fix
  1. BJosephus
    Gingerbread May 9, 2015
    #41
  2. 2emkay
    2emkay , May 9, 2015 :
    Yeah it says mobile radio. I have no clue what that is.
    #42
  3. 2emkay
    Does this happen even when data is off?
    #43
  4. redleema
    KitKat May 9, 2015
    redleema , May 9, 2015 :
    Not sure tbh. You can test this if you switch on your wifi. If matters does hugely improve, I guess that could go down as a bug. Controlling wakelocks & other battery saving tips can be found on other threads.
    #44
    2emkay likes this.
  5. DaphPunk
    Donut May 9, 2015
    DaphPunk , May 9, 2015 :
    Hey everyone,
    I'm having battery draining issues since the new update.
    I have already turned off wake up and keep awake functions for most google apps (not for facebook, whatsapp, etc) and when I'm not using my opo it's fine but when I start using it something happens and it drains my battery.
    I have included a screenshot of my battery usage.
    I hope someone knows what's wrong since I didn't have these issues before the update.
    Thanks and cheers!
    #45
  6. Hagayj
    Cupcake May 10, 2015
  7. SomeSayImHandSome
    May 10, 2015
  8. isaaccallan
    Gingerbread May 10, 2015
    isaaccallan , May 10, 2015 :
    Wow, how did you get this, mine won't last the day.
    #48
    chongswee likes this.
  9. Aayan99
    #49
  10. chongswee
    Jelly Bean May 10, 2015
    chongswee , May 10, 2015 :
    You can try install those save battery app, one by one, I tried 5 apps then only found the one not drain in my opo with CM 12 and help me save power. Not all the apps match your profile ( time for screen on, email, social ...etc ).
    #50
  11. Ostro
    Donut May 10, 2015
    Ostro , May 10, 2015 :
    If I close an app with a swipe, I want it to be fully closed. If I only quit an app, it may be in the background.
    Going to apps and force close all bad ones is an unnecessary hassle. I use Chrome multiple times a day and don't want to do that every time just because the devs thought it's cool to have Chrome running all the time for whatever reason.
    Any way to tell them this is bad? At least make an option for "keep running in background, even if fully closed" so I don't lose battery for some weird Google stuff that is going on and on.
    #51
  12. gringoboy
    Lollipop May 10, 2015
    gringoboy , May 10, 2015 :
    I know it's a pain, but it's a workaround until its fixed by whoever messed it up. That's all you can do with Android unless you want to go installing new roms etc. Updates are not as speedy as with Apple, and must be more complex due to the huge amount of manufacturers using the same software on a plethora of devices.
    #52
  13. TakeMyMoney
    KitKat May 10, 2015
    #53
  14. damnshah
    #54
  15. sreenu_ksr
    #55
  16. JustSaying
    Gingerbread May 11, 2015
    JustSaying , May 11, 2015 :
    my perfermonce is on power saver and i always turn data and wifi off if i dont use it lol
    #56
  17. sayem
    Eclair May 11, 2015
    sayem , May 11, 2015 :
    Why battery graph shows "wifi on" always, while i turn off wifi at night when i go to sleep.
    Is anyone having with the same issue??
    Image attached: [​IMG]
    #57
    2emkay likes this.
  18. Suneth
    Honeycomb May 11, 2015
    Suneth , May 11, 2015 :
    I used to have the same issue. about 10% over night.
    Do you have OK oneplus turned on? turn it off.
    Go to Settings --> Language and input --> Voice wakeup
    #58
    2tuf likes this.
  19. anilchelli
    anilchelli , May 11, 2015 :
    How do people get 2days , 3days battery life ?? In last 8 months it never lasted single day for me .. :( .
    Do those people use any apps at all on their OPO ?? or simply call n text ??
    #59
    isaaccallan likes this.
  20. daedal
    daedal , May 11, 2015 :
    as far as I know, nothing yet. maybe cyan will think something for upcoming updates.
    hope it'll be solved soon, since it's rather annoying.
    #60
